Question: How can I create a Vector using symbolic name for the entries and then modify the entries using the symbolic name?
I have the following example.
> A:= Vector(3,symbol=v)
>v[1]:= 5
v[1]:=5
> A
 Vector(3,symbol=v)
Is there any way such that v[1] is actually referring to the first element in the vector? In other words, changing v[1] actually modifies the vector A.
If the question does not make sense, then here is the actual scenario that I faced.
I need to solve a system of equations in the form of
2 = c[2] + a[1],
2 = 2*c[3] + a[2],
-2 = -3*c[1] + a[3],
-1 = -2*c[2] + a[1],
-1 = -c[3] + a[2],
1 = a[3]
where a[i], c[i] refers to the entries in the vector.
solve returns the following:
[[a[1] = 1, a[2] = 0, a[3] = 1, c[1] = 1, c[2] = 1, c[3] = 1]]
I then did an assign(%). However, the entries in A and C are not changed. I want the answer returned by solve to be properly applied to the entries of the vectors.
