Question: how to set DynamicSystems continuoustimevar to something other than t ?
I have differential equation with x as independent variable that I want to convert to state space representation.
But DynamicSystems will not accept y(x) as the output variable, since it defaults to y(t).
Help under "Description of the Model of a Linear System Object" says it is possible to change the independent variable by changing continuoustimevar setting. But help does not give an example how to do this and all my tries failed.
How to do this? Attached is worksheet showing the problem
`Standard Worksheet Interface, Maple 2022.1, Windows 10, May 26 2022 Build ID 1619613`
ode:=diff(y(x),x$2)+y(x) = 0;
DynamicSystems:-DiffEquation(ode,'outputvariable'=[y(x)]);
diff(diff(y(x), x), x)+y(x) = 0
Error, (in DynamicSystems:-DiffEquation) missing output(s): {y(t)}
ode := diff(y(t),t$2) + y(t) =0;
sys:=DynamicSystems:-DiffEquation(ode,'outputvariable'=[y(t)]);
ode := diff(y(t), t, t)+y(t) = 0
_m2541722345344
Download DS_problem.mw
