Question: Can I disable maple's use of the ' function?(aka prime notation/derivative function)
restartNULL
NULL``
Can I disable maple's use of the ' function? (aka prime/derivative function)
For example, if
f := x^2+1
x^2+1
it's derivative is obtained as
Diff(f(x), x) = diff(f(x), x)
Diff(x^2+1, x) = 2*x
We used the prime operator on the f to obtain f' on the right-hand-side.
The problem is, I use prime notation as a naming convention like in defining an integral equation such as:
"psi(t)=∫G(t,t')*psi(t') ⅆt' ."
This is common practice in many texts.
Is there a way that I can disable the operator function of ' so I can use it as a naming scheme? I have tried using the Alias( ) command which works on one evaluation but if an equation is passed to another function the Alias( ) command is extinguished by the previous evaluation and it takes the derivative again which is undesired.
how_do_i_disable_prime_operation.mw
