Question: Solve ODE in fourier space numerically and transform to real space
Dear all,
consider two lists of complex values :
list1 := [l1,l2,l3,l4,l5]
list2 := [s1,s2,s3,s4,s5].
There is a set of second order differential equation
d^2u(k)/dt^2+I*A*du/dt-B*u=0
where A is sum of elements of list1 and list2 and B is multiplication of their element. Therefore,
d^2u[1](k)/dt^2+I*(l1+s1)*du[1]/dt-(l1*s1)*u[1]=0
d^2u[2](k)/dt^2+I*(l2+s2)*du[2]/dt-(l2*s2)*u[2]=0
d^2u[3](k)/dt^2+I*(l3+s3)*du[3]/dt-(l3*s3)*u[3]=0
d^2u[4](k)/dt^2+I*(l4+s4)*du[4]/dt-(l4*s4)*u[4]=0
d^2u[5](k)/dt^2+I*(l5+s5)*du[5]/dt-(l5*s5)*u[5]=0
How can I create a set of differential equations and initial conditions based on nops(list1), then solve this system of differential equations numerically in Maple.
since u[i] are function of k, next step is to transforme them to real space by inverse fourier transform.
finally save the results and plot them.
Note that for simplisity I wrote a linear equation but it is not. so, because of nonlinear terms it is not possible to use superposition of the solution. I have to take them as coupled system of equations.
for example
list1 := [ [0., -5.496799068*10^(-15)-0.*I], [.1, 5.201897725*10^(-16)-1.188994754*I], [.2, 6.924043163*10^(-17)-4.747763855*I], [.3, 2.297497722*10^(-17)-10.66272177*I], [.4, 1.159126178*10^(-17)-18.96299588*I] ]
list2 :=[ [0., -8.634351786*10^(-7)-67.81404036*I], [.1, -0.7387644021e-5-67.76491234*I], [.2, -0.1433025271e-4-67.59922295*I], [.3, -0.2231598645e-4-67.25152449*I], [.4, -0.3280855430e-4-66.56357035*I] ]
where first element is k and the second value is l_i and s_i
the differential equation is
ode_u[i]:= diff(u[i](t),t$2)+I*(list1[i][2]+list2[i][2])*diff(u[i](t),t)-list1[1][2]*list2[2][2]*u[i](t)=0;
eta is in fourier space where k values are in list1[i][1].
We laso know that f(-k)= - f*(k) where f=list[i][2]
and u[i] as function of k, initially has a Gaussian shape at t=0 in fourier space..
Thanks in advance for your help
