Question: Error, invalid if statement termination
Why there is an error? Is any part missing in the if statement?
rel := w+(1/2)*sqrt(960*c^6*gamma^2*k^2-336*c^4*gamma^2*k^4+64*c^2*gamma^2*k^6-4*gamma^2*k^8+576*alpha*c^6*gamma*k-288*alpha*c^4*gamma*k^3-16*alpha*c^2*gamma*k^5+8*alpha*gamma*k^7-144*alpha^2*c^4*k^2-48*alpha^2*c^2*k^4-4*alpha^2*k^6+128*c^4*gamma*k^2-40*c^2*gamma*k^4+4*gamma*k^6+48*alpha*c^4*k-16*alpha*c^2*k^3-4*alpha*k^5+4*c^2*k^2-k^4)
w+(1/2)*(960*c^6*gamma^2*k^2-336*c^4*gamma^2*k^4+64*c^2*gamma^2*k^6-4*gamma^2*k^8+576*alpha*c^6*gamma*k-288*alpha*c^4*gamma*k^3-16*alpha*c^2*gamma*k^5+8*alpha*gamma*k^7-144*alpha^2*c^4*k^2-48*alpha^2*c^2*k^4-4*alpha^2*k^6+128*c^4*gamma*k^2-40*c^2*gamma*k^4+4*gamma*k^6+48*alpha*c^4*k-16*alpha*c^2*k^3-4*alpha*k^5+4*c^2*k^2-k^4)^(1/2)
crit_points := solve(diff(rel, k) = 0, k); rel_at_crit := subs(k = crit_points, rel)
"#` determine the maxima and minima by checking the sign of the second derivative at the critical points`  for i from 1 to nops(crit_points) do    if (eval(diff(diff(rel, k), k), k = crit_points[i]) > 0) then      print("Minimum at k = ", crit_points[i], " with value ", rel_at_crit[i]);    else if (eval(diff(diff(rel, k), k), k = crit_points[i]) < 0) then      print("Maximum at k = ", crit_points[i], " with value ", rel_at_crit[i]);    else      print("Saddle point at k = ", crit_points[i], " with value ", rel_at_crit[i]);    end if;  end do; "
Download maxnmin.mw
