Question: better way to remove entries in piecewise which contains undefined?
Could you suggest a more elegent way to remove any entry in piecewise which has undefined in it?
expr:=(s+exp(-Pi*s)-exp(-2*Pi*s))/(s*(s^2+2*s+2));
inttrans:-invlaplace(expr,s,t);
Y:=convert(%,piecewise);
#remove all entries in piecwise which has undefined
To obtain this
I can;t just apply select on piecewise. So currently I convert piecwise to list of lists, each sublist has the 2 entries you see above in each row.
Next apply select. Then use piecewise again on the result. This works, but wondering if there is a better way.
Attached worksheet.
`Standard Worksheet Interface, Maple 2022.2, Windows 10, October 23 2022 Build ID 1657361`
expr := (s+exp(-Pi*s)-exp(-2*Pi*s))/(s*(s^2+2*s+2))
exp(-t)*sin(t)+(1/2)*(-1+exp(-t+2*Pi)*(cos(t)+sin(t)))*Heaviside(t-2*Pi)+(1/2)*(1+exp(-t+Pi)*(cos(t)+sin(t)))*Heaviside(t-Pi)
piecewise(t < Pi, exp(-t)*sin(t), t = Pi, undefined, t < 2*Pi, exp(-t)*sin(t)+1/2+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)), t = 2*Pi, undefined+(1/2)*exp(-Pi), 2*Pi < t, exp(-t)*sin(t)+(1/2)*exp(-t+2*Pi)*(cos(t)+sin(t))+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)))
Y:=[op(Y)]:
Y:=seq([Y[n],Y[n+1]],n=1..nops(Y)-1,2):
ListTools:-Flatten(select(not has,[Y],'undefined')):
piecewise(op(%))
piecewise(t < Pi, exp(-t)*sin(t), t < 2*Pi, exp(-t)*sin(t)+1/2+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)), 2*Pi < t, exp(-t)*sin(t)+(1/2)*exp(-t+2*Pi)*(cos(t)+sin(t))+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)))
Download remove_undefined.mw
