Question: Using Assumptions & Missed Solutions in calling solve?
The help page solve/details claims that solve(x^2-1,{x}, useassumptions) assuming x>0; is equivalent to solve({x^2-1, x>0},{x});. But the following example perplexes me again.
Considering a multi-variable polynomial:
expr := 36*a^3*b^3+8*a^2*b^2*(9*(a+b+1)^2+4*(a*b+a+b))*(a+b+1)+((a-b)^2-2*(a+b)+1)^2*(a+b+1)^5+a*b*((a-b)^2-2*(a+b)+1)*(17*(a+b+1)^2+4*(a*b+a+b))*(a+b+1)^2: # assuming nonnegative
I intend to find the non-negative real roots of it.
solve({expr = 0, (a, b) >= ~ 0}, [a, b], allsolutions);
solve(expr = 0., [a, b], useassumptions, allsolutions) assuming (a, b) >= ~ 0;
solve({expr = 0., (a, b) >= ~ 0}, [a, b], allsolutions);
all return six solutions, but curiously,
solve(expr = 0, [a, b], useassumptions, allsolutions) assuming (a, b) >= ~ 0;
only returns four solutions. Why???
In addition, as you can see, the first output (i.e., sol1) is thoroughly less meaningful. Can't it be more readable??
sol1 := solve({`~`[`>=`](a, b, ` $`, 0), expr = 0}, [a, b], allsolutions) =
[[a = 0, b = 1], [a = 3^(1/2)-1, b = RootOf((-741235976922591048947725497133370413109846163676281959390560108171291511786260537194814187602376638467882392432305864*3^(1/2)+1283858372427879519277780718816094877088966867890478064541174875107114975191197490158346515516574907111238006510832897)*_Z^8+(542622395505288470330055221682724463979120704214196105150614766935823463404936952963532327914198268643355614078527033*3^(1/2)-939849558339893627565395772584016362240571623138367813630505449406759560167584121426096047290555008292409170786084695)*_Z^7+(27663303262730616171732317130828357033086591952430419833222950914496979987637185645479748907213281840470027913754446250*3^(1/2)-47914246756235321853987379290323009935074722268098020072540300747281044857411765919011355938402797296261231903185833860)*_Z^6+(-36848925451143075385294452437991667121840085487125852139251120381482252862356891660819456375517484560073220737684055360*3^(1/2)+63824211085697719773601999676355867125229886950052051470652732444578522019946850568834704346278726602905590979989005206)*_Z^5+(-361541600067355242269699717707379679953498397064818094940691654358197984962782803819129269994590941790029033835785321091*3^(1/2)+626208420366406708672813369852190896907780666621957659007533759258885959287096424079349105562785060297582745252447270847)*_Z^4+(469917886838763314544262854134623783463102170709338866937842556434901449696233730989733509809486602395675273592523379039*3^(1/2)-813921655390140293483357785790922432834508040979560342164969934794994487106266639300148834412459020073129881509269947685)*_Z^3+(2419091701164731099042357448446421888413075728672522494523180828886450053865285232431099171783692236478370266582727759022*3^(1/2)-4189989734585541679787610388006771626857619186946433018568920261866881451820006582050966407487366628715776067639375659568)*_Z^2+(-276526595929812923186277260098945143564039808175960075417091066631428638512893788855336862569832144723039829695578843580*3^(1/2)+478958113794505090444730274771005660986137994458744274847200001817421835204311147220572248669252963586284164359082018778)*_Z-2241557156236496486338463519192106892320755475146925672942972549523504139162741341146795559700763371271548957041603585449*3^(1/2)+3882490882671219790342097523842232566093205006918585285230133334462570311857306952032638288791685675699575851624588398080, index = real[4])], [a = 1, b = 0], [a = 1, b = 3^(1/2)-1], [a = 1, b = 1], [a = 1/2+(1/2)*3^(1/2), b = RootOf((3265859930834838622581170032695923790177759993209560990735389424723672715638564736*3^(1/2)+5656635330609319983539361351500545583607599001912359529744925502462343818424446992)*_Z^8+(12188355192278997228701701416892393163963118988331481511215704351909689249701576464*3^(1/2)+21110850453723155834822232801088862537748477983453402031696019279095705783764588192)*_Z^7+(-16329299654174193112905850163479618950888799966047804953676947123618363578192823680*3^(1/2)-28283176653046599917696806757502727918037995009561797648724627512311719092122234960)*_Z^6+(-47558033069228748234327710008167261759137556448974526775358049368769421447413364728*3^(1/2)-82372929583945025397186856831061837257531071444955446405553455730528485970812729160)*_Z^5+(71016746435016238932635448066739883738739336153617153345258159361269798232579788444*3^(1/2)+123004613013684064253013423478212462789515684702771043974383244940692061281906669908)*_Z^4+(-539074301591972734261861623983834399153978765971327430710378028630584341753429268*3^(1/2)-933704079412004867600664919608623045951401970711134655767859337789085046795723776)*_Z^3+(-8660811640968922793242100644402781523021841461481655906743406226105766029465794376*3^(1/2)-15000965796942156111966381948246207258139974790596863072851606476670777826354805396)*_Z^2+(-30769734905669303241874027457081560634086527346916553595415452889491557012102176442*3^(1/2)-53294744192044789072581100596045559567736905080848045509547703544202848750472876382)*_Z-3181857373467742490740890760219056890779274438575702235481520595135068397863751433*3^(1/2)-5511138633283790175605724430174371395924969988541134171865969654221197707640077992, index = real[4])]]
sol2 := `assuming`([solve(expr = 0., [a, b], useassumptions, allsolutions)], [`~`[`>=`](a, b, ` $`, 0)]) =
[[a = 0., b = 1.], [a = .7320508076, b = 1.000000000], [a = 1., b = 0.], [a = 1., b = .7320508076], [a = 1., b = 1.], [a = 1.366025404, b = 1.366025404]]
sol3 := solve({`~`[`>=`](a, b, ` $`, 0), expr = 0.}, [a, b], allsolutions) =
sol4 := `assuming`([solve(expr = 0, [a, b], useassumptions, allsolutions)], [`~`[`>=`](a, b, ` $`, 0)]) = [[a = 0, b = 1], [a = 1, b = 0], [a = 1, b = 3^(1/2)-1], [a = 1, b = 1]]NULL
_SolutionsMayBeLost;
_SolutionsMayBeLost
numelems(sol1), numelems(sol2), numelems(sol3), numelems(sol4) = 6, 6, 6, 4NULL
sol5 := [[a = 0, b = 1], [a = sqrt(3)-1, b = 1], [a = 1, b = 0], [a = 1, b = sqrt(3)-1], [a = 1, b = 1], [a = (sqrt(3)+1)*(1/2), b = (sqrt(3)+1)*(1/2)]]
Why did't solve({`~`[`>=`](a, b, ` $`, 0), expr = 0}, [a, b]) return sol5?
map2(evala@eval, expr, sol5);
[0, 0, 0, 0, 0, 0]
Error, (in type/algext) too many levels of recursion
Download solve_details.mw
