Question: I can not explore the error when I run this code below but error's message is"Error, invalid subscript selector"
Frac_C := proc (expr, a, t, alpha) local ig, m, tau;
m := ceil(alpha);
ig := (t-tau)^(m-alpha-1)*(diff(eval(expr, t = tau), tau$m));
`assuming`([(int(ig, tau = a .. t))/GAMMA(m-alpha)], [a < t]);
end proc;
r := .5;
k := .7;
eq1 := Frac_C(x, 0, t, r)-y(t) = 0;
eq2 := Frac_C(y, 0, t, k)-x(t)-2*t = 0;
eq3 := x(0)-y(1) = 0;
eq4 := Frac_C(x, 0, t, r)-(eval(diff(y(x), x), x = 1)) = 0;
eq5 := Frac_C(x, 0, t, r)-(eval(diff(y(x), x, x), x = 1)) = 0;
eq6 := eval(diff(y(x), x), x = 0)-x(1)-2 = 0;
eq7 := y(0) = 0;
N := 5;
x[c] := [seq(a[i], i = 0 .. N)];
y[c] := [seq(b[i], i = 0 .. N)];
for n to N do
subs([seq(x(i) = x[c][i], i = 0 .. n), seq(y(i) = y[c][i], i = 0 .. n)], {eq1, eq2, eq3, eq4, eq5, eq6, eq7});
soln := solve({eq3, eq4, eq5, eq6, eq7, seq(coeff(lhs(eq), t, j) = 0, eq in {eq1, eq2})}, {a[n+1], b[n+1]});
x[c][n+1] := eval(a[n+1], soln);
y[c][n+1] := eval(b[n+1], soln);
end do;
x[s] := add(x[c][i]*t^(i-1), i = 1 .. N+1);
y[s] := add(y[c][i]*t^(i-1), i = 1 .. N+1);
x[s];
y[s];
