Question: How to access menus when window is maximized?
There appears to be a bug in Maple 2023.0 (Build ID 1689885)  that does not allow you to access submenus when the window is maximized.  For example, trying to select "Insert --> Execution Group" does not work, nor does any other submenu (the submenu will not display and is not accessible).  The only workaround is to un-maximize the window, select the submenu (for example "Insert --> Execution Group --> Before Cursor"), and then re-maximize the window.  Everything works as it should as long as the window is not maximized.  This is on Microsoft Windows 11 with a 2160p monitor.  Any suggestions on how to fix this are appreciated.
