Question: How to evaluate a one-dimensional improper integral of an irregularly oscillatory function numerically?
The highly oscillatory integrand is:
(sin(x + sqrt(x)) + x*BesselJ(0, x^2))/(1 + x): # int(%, x = 0 .. infinity, numeric); # Note that the upper limit of `x` is NOT finite.
Unfortunately, Maple still cannot return a result in a few minutes. For instance,
infolevel[`evalf/int`] := 1:
smartplot((sin(x+sqrt(x))+x*BesselJ(0, x^2))/(1+x))
timelimit(0.1e3, evalf(Int((sin(x+sqrt(x))+x*BesselJ(0, x^2))/(1+x), x = 0 .. infinity)))
Control: Entering NAGInt
trying d01amc (nag_1d_quad_inf)
Control: d01amc failed
evalf/int/control: NAG failed result = result
evalf/int/improper: integrating on interval 0 .. infinity
evalf/int/improper: applying transformation x = 1/x
evalf/int/improper: interval is 0 .. 1 for the integrand:
                        /     (1/2)\            /    2\
                     sin\x + x     / + x BesselJ\0, x /
                                   1 + x
and interval is 0 .. 1 for the integrand:
                                                /   1 \
                                         BesselJ|0, --|
                        /       (1/2)\          |    2|
                        |1   /1\     |          \   x /
                     sin|- + |-|     | + --------------
                        \x   \x/     /         x
                                 /    1\  2
                                 |1 + -| x
                                 \    x/
Control: trying d01ajc (nag_1d_quad_gen)
Control: d01ajc failed
evalf/int/control: singularity at left end-point
evalf/int/transform: series contains {x^(1/2), x^(3/2), x^(5/2), x^(7/2), x^(9/2), x^(11/2), x^(13/2), x^(15/2), x^(17/2), x^(19/2), x^(21/2), x^(23/2), x^(25/2)}
evalf/int/singleft: applying transformation x = x^2
evalf/int/singleft: interval is 0 .. 1. for the integrand:
                  /   / 2            \    2        /    4\\
                2 \sin\x  + csgn(x) x/ + x  BesselJ\0, x // x
                                        2
                                   1 + x
evalf/int/control: Applying simplify/ln, integrand is 2*(sin(x^2+x)+x^2*BesselJ(0,x^4))/(1+x^2)*x
evalf/int/CreateProc: Trying easyproc
evalf/int/CreateProc: Trying makeproc
evalf/int/ccquad: n = 2 integral estimate = .7758263476953
                    n = 6 integral estimate = .8097413335347
evalf/int/ccquad: n = 18 integral estimate = .8097470386638
                                  error = .8097470386638e-11
From ccquad, result = .8097470386638 integrand evals = 19 error = .8097470386638e-11
evalf/int/transform: series contains {1/x^(3/2), x^(1/2), cos(1/x^2+1/4*Pi), sin((x+x^(1/2))/x^(3/2)), sin(1/4*(4+Pi*x^2)/x^2)}
                   /   /        /1\  \                    \
                   |   |1 + csgn|-| x|                    |
                   |   |        \x/  |  2          /   1 \|
                 2 |sin|-------------| x  + BesselJ|0, --||
                   |   |      2      |             |    4||
                   \   \     x       /             \   x //
                                 3 /     2\
                                x  \1 + x /
evalf/int/control: Applying simplify/ln, integrand is 2*(sin((1+x)/x^2)*x^2+BesselJ(0,1/x^4))/x^3/(1+x^2)
evalf/int/control: Applying simplify/trig, integrand is (2*sin((1+x)/x^2)*x^2+2*BesselJ(0,1/x^4))/(x^3+x^5)
evalf/int/transform: series contains {cos(1/x^4+1/4*Pi), sin((1+x)/x^2), sin(1/4*(4+Pi*x^4)/x^4)}
evalf/int/transform: no transform found
evalf/int/series: integrating on 0 .. .2493468135214 the series:
       2 (%2)     2 (%2) x   /2 (%2)      \  3   /  2 (%2)      \  5
      --------- - -------- + |------- - %3| x  + |- ------- + %3| x
        (1/2)       (1/2)    |  (1/2)     |      |    (1/2)     |
      Pi      x   Pi         \Pi          /      \  Pi          /
           /       2 (%2)      \  7   /     2 (%2)      \  9
         + |- %3 + ------- - %4| x  + |%3 - ------- + %4| x
           |         (1/2)     |      |       (1/2)     |
           \       Pi          /      \     Pi          /
           /2 (%2)           \  11   /          2 (%2) \  13
         + |------- - %4 - %5| x   + |%4 + %5 - -------| x
           |  (1/2)          |       |            (1/2)|
           \Pi               /       \          Pi     /
           /       2 (%2)      \  15   /     2 (%2)      \  17    / 19\
         + |- %5 + ------- + %6| x   + |%5 - ------- - %6| x   + O\x  /
           |         (1/2)     |       |       (1/2)     |
           \       Pi          /       \     Pi          /
                      /        4\
             (1/2)    |4 + Pi x |
      %1 := 2      sin|---------|
                      |     4   |
                      \  4 x    /
                    /1 + x\   (1/2)
      %2 := %1 + sin|-----| Pi
                    |  2  |
                    \ x   /
             (1/2)    /1    1   \
            2      cos|-- + - Pi|
                      | 4   4   |
                      \x        /
      %3 := ---------------------
                      (1/2)
                  4 Pi
                        /        4\
               (1/2)    |4 + Pi x |
            9 2      sin|---------|
                        |     4   |
                        \  4 x    /
      %4 := -----------------------
                       (1/2)
                  64 Pi
                (1/2)    /1    1   \
            53 2      cos|-- + - Pi|
                         | 4   4   |
                         \x        /
      %5 := ------------------------
                        (1/2)
                  512 Pi
                           /        4\
                  (1/2)    |4 + Pi x |
            1371 2      sin|---------|
                           |     4   |
                           \  4 x    /
      %6 := --------------------------
                          (1/2)
                  16384 Pi
evalf/int/CreateProc: Trying procmake
evalf/int/control: applying double-exponential method
evalhf mode unsuccessful -- retry in software floats
evalf/int/quadexp: applying double-exponential method
Error, (in tools/sign) time expired
time() =
3999.500
Download oscillatoryInt.mws
I tried to specify another method (as described in evalf/int), but it seems that this doesn't work. Any ideas?
