Question: Calculating deviation with derivatives
Ive followed the examples, and yet not the result the book gave. The question before this one, same type, and i did get the right answer there.
Would you have a clue why it is not going as planned?
Translation: "Through a resistancewire with the measured resistance R= (1.5+-0.5)Ohm goes an electric current with the measured strength I= (2.5+-0.05)A, During a timespan of t=(10+-0.5)s develops an amount of heat Q=RI^2*t. Give the estimate of the maximum relative deviation in Q."
Here i got the right answer of .42, and yet when doing the exact same thing in assignment 4, i got the wrong answers.
Translation: "Two bodies with mass M and m have a massmidpointdistance r. For the gravitational force between these bodies counts: F=y*M*m/r^2, at which y is the gravitational constant. Give an estimation of the maximum realative deviation in F on ground of the following measurementdata: M=(7.0+-0.05)kg, m=(2.0+-0.02)kg and r=(5.0)+-0.05)m."
I had the answer -0.0029. The books says its wrong, but i cant see what i did wrong.
Translation of the example: "According to the law of Ohm the currentstrength in the stream(/current)circle(circuit) with tension(voltage) U and resistance R is equal to I=U/R. For a given currentcircle((part of a)circuit) is given: U=(30.0+-0.05)Volt and R=(2.5+-0.03)Ohm. Determine the maximum absolute and relative deviation in I.
Solution
The maximum absolute deviation in I is
This gives the currentstrength:
The maximum realtive deviation in I is: .... or about 1.4%"
Could somebody tell me what i am doing wrong?
Thank you!
Greetings,
The Function
#opdracht 3
R := 1.5; A := 2.5; t := 10; Q := R*A^2*t
1.5
2.5
10
93.750
Q := R*A^2*t
R*A^2*t
diff(R*A^2*t, R)
A^2*t
diff(R*A^2*t, A)
2*R*A*t
diff(R*A^2*t, t)
R*A^2
1.5
2.5
10
.5*A^2*t+2*R*A*t*0.5e-1+.5*R*A^2
39.6875
Q := R*A^2*t
93.750
.4233333333
#Opdracht 4
M := 7; m := 2; r := 5; F := y*M*m/r^2
7
2
5
(14/25)*y
diff(y*M*m/r^2, M)
y*m/r^2
diff(y*M*m/r^2, m)
y*M/r^2
diff(y*M*m/r^2, r)
-2*y*M*m/r^3
M := 7; m := 2; r := 5; y := 9.81
7
2
5
9.81
(14)
0.5e-1*y*m/r^2+0.2e-1*y*M/r^2+(-2*y*M*m/r^3)*0.5e-1
-0.1569600000e-1
(15)
F := y*M*m/r^2
5.493600000
(16)
-0.1569600000e-1/(5.493600000)
-0.2857142857e-2
(17)
Download Mapleprimes_Question_Book_2_Paragraph_5.13_Question_4.mw
