Question: Why does isolate fail to isolate?
In a recent answer I posted, I had a relation of the form
I*Int(f(x), x) = something - 2*I*Int(f(x), x)
and I wanted to isolate the term Int(f(x), x).
The function isolate failed to do it and I was forced to use some workaround to do the "isolation".
Trying to understand what happened here, it seems that isolate fails when the term to isolate is multiplied by the imaginary unit
Here are a few examples
expr := I*(Int(x^2*ln(-x+sqrt(x^2-1)), x)) = g(x) -(2*I)*(Int(x^2*ln(-x+sqrt(x^2-1)), x))
I*(Int(x^2*ln(-x+(x^2-1)^(1/2)), x)) = g(x)-(2*I)*(Int(x^2*ln(-x+(x^2-1)^(1/2)), x))
# no isolation
isolate(expr, lhs(expr))
# isolation
expr_1 := expand(expr / I)
isolate(expr_1, lhs(expr_1))
Int(x^2*ln(-x+(x^2-1)^(1/2)), x) = -((1/3)*I)*g(x)
# no isolation neither, so the problem is not related to "Int"
expr := I*diff(h(x), x) = g(x) -2*I*diff(h(x), x):
I*(diff(h(x), x)) = g(x)-(2*I)*(diff(h(x), x))
# no isolation neither, so the problem comes from "I"
expr := I*A = g(x) -2*I*A:
I*A = g(x)-(2*I)*A
# isolation (of course)
expr := c*A = g(x) -2*c*A:
c*A = (1/3)*g(x)
Download Isolation.mw
I guess this is a known behavior, but why it is so?
Is there a way to force the "isolation" without using a trick like in result (3)
Thanks in advance
