Question: How do i retrieve the expression from a "Fit" command
How do i retrieve the expression fra a "Fit" command so that i can use the expression for later calculations.
As you can see from the picture below, i use the "Fit" command to find an expression based on the values specified in X and Y. From there i would like to use the expression to find points on the line and to automate the proces. I can succesfully retrieve the expression by using the reference label, but is there another way to retrieve the expression so that i can avoid having to display the expression after evaluating?
I guess the question can be rephrased to: How do i retrieve the same information as the label reference does, but with a command and without using a label reference?
