Question: Should this be considered a simplify bug?
A case where simplify(...) and simplify~(...) both return the wrong result.
Should we consider this a simplify bug?
A simple case
J := Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity)
     Int(r[2]^2*varphi[2](r[2]), r[2] = -infinity .. infinity)
(Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[2]^2*varphi[2](r[2]), r[2] = -infinity .. infinity))
# OK
op(1, J) = simplify(op(1, J))
Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity) = Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity)
# OK
op(2, J) = simplify(op(2, J))
Int(r[2]^2*varphi[2](r[2]), r[2] = -infinity .. infinity) = Int(r[2]^2*varphi[2](r[2]), r[2] = -infinity .. infinity)
# But...
# Not OK
simplify(J)
(Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[1]^2*varphi[2](r[1]), r[1] = -infinity .. infinity))
# Not OK
simplify~(J)
# OK
map(simplify, J)
A slightly more complex case
J := (Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[2]^2*varphi[2](r[2]), r[2] = -infinity .. infinity))-(Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[2]*varphi[2](r[2]), r[2] = -infinity .. infinity))^2;
is(J=simplify(J))
false
is(J=simplify~(J))
false
is(J=map(simplify, J));
map(simplify, J);
false
(Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[1]^2*varphi[2](r[1]), r[1] = -infinity .. infinity))-(Int(r[1]^2*varphi[1](r[1]), r[1] = -infinity .. infinity))*(Int(r[1]*varphi[2](r[1]), r[1] = -infinity .. infinity))^2
add(map(u -> map(simplify, u), [op(J)]));
is(J=%);
true
Download Simplify_is_wrong.mw
