Question: How do I control the stacking order of plot structures in plots['display']?
For example, I would like to draw the following figure in Maple.
(The above figure is taken from MatLab's documentation.)
Here are these four graphics objects:
use plottools, ColorTools in
	l0, l1 := line~([<1 | 0>, <1 | 1>], [<6 | 5>, <6 | 6>], 'color' =~ Color~(["#0072BD", "#D95319"]))[];
	r0, r1 := rectangle~([[2, 0], [4, 0]], [[3, 6], [5, 6]], 'color' =~ Color~([[.6, .7, .9], [.95, .7, .6]]))[]
end:
However, either
`plots/display`([r1, l1, l0, r0], 'axes' = "boxed", 'size' = ["default", "golden"], 'style' = "patchnogrid")
or
`plots/display`([r0, l0, l1, r1], 'axes' = "boxed", 'size' = ["default", "golden"], 'style' = "patchnogrid")
outputs the same graphical image where the lines are always rendered on top of each rectangles instead of the other way around.
plots:-display([plottools:-rectangle([2, 0], [3, 6], 'color' = ColorTools:-Color([.6, .7, .9])), plottools:-line([1, 0], [6, 5], 'color' = ColorTools:-Color(
So how to superimpose the right rectangle over the two lines? To put it differently, how to handle the graphics hierarchy? I have read some similar questions like Order in plots:-display - MaplePrimes, yet I cannot find any workarounds.
Note that in my opinion, the result should comprise two unbroken line segments rather than four subordinate line segments!
