Question: Match the `seq` modifier?
It seems that applyrule cannot handle variable numbers of arguments, and I cannot use something like
applyrule(f(u::anything, v::seq(anything)) = g(v, u), [f(x, y, z), f(x, y, z, t)]);
Strangely, Maple does support the identical patterns in parameter declarations:
eval([f(x, y, z), f(x, y, z, t)], f = ((u::anything, v::seq(anything)) → g(v, u)));
                  [g(y, z, x), g(y, z, t, x)]
So the two designs do not appear coherent. Should this be regarded as a "bug" in a sense?
Of course there is no need to use the seq modifier; here it is enough to use
evalindets([f(x,y,z),f(x,y,z,t)],'specfunc'(anything,f),w->g(op(2..(),w),op(1,w))):
use f = MakeFunction('g(args[2 .. ], args[1])') in [f(x, y, z), f(x, y, z, t)] end:
use f = unapply('g(_rest, _w)', [_w::anything]) in [f(x, y, z), f(x, y, z, t)] end:
But the problem is, why is there such inconsistency described above?
