Question: 'n' and 'm' are real
As I assumed 'n' and 'm' are real, eta is complex. But still, there is a bar on these discrete independent variables. Secondly, the substitution of (8) applies in some terms of 'r2', and the remaining terms remain as is it.
with(LinearAlgebra); with(PDEtools); with(plots); with(LREtools)
setup(mathematicalnotation = true)
assume(n::real); assume(m::real)
A := proc (n, m) options operator, arrow; Matrix([[eta*phi(n, m), conjugate(eta)*conjugate(psi(n, m))], [phi(n, m), conjugate(psi(n, m))]]) end proc; Adet := Determinant(A(n, m))
eta*phi(n, m)*conjugate(psi(n, m))-conjugate(eta)*conjugate(psi(n, m))*phi(n, m)
B := proc (n, m) options operator, arrow; Matrix([[phi(n, m), conjugate(psi(n, m))], [-psi(n, m), conjugate(phi(n, m))]]) end proc; Bdet := Determinant(B(n, m))
phi(n, m)*conjugate(phi(n, m))+conjugate(psi(n, m))*psi(n, m)
r := Adet/Bdet
(eta*phi(n, m)*conjugate(psi(n, m))-conjugate(eta)*conjugate(psi(n, m))*phi(n, m))/(phi(n, m)*conjugate(phi(n, m))+conjugate(psi(n, m))*psi(n, m))
p := {eta = 1+I, phi(n, m) = (1+I*a*eta)^n*(1+I*b*eta^2)^m, psi(n, m) = (1-I*a*eta)^n*(1-I*b*eta^2)^m, conjugate(eta) = 1-I, conjugate(phi(n, m)) = (1-I*a*conjugate(eta))^n*(1-I*b*conjugate(eta)^2)^m, conjugate(phi(n, m)) = (1+I*a*conjugate(eta))^n*(1+I*b*conjugate(eta)^2)^m}
r1 := simplify(subs(p, r))
(2*I)*(1+I*a*eta)^n*(1+I*b*eta^2)^m*conjugate((1-I*a*eta)^n*(1-I*b*eta^2)^m)/((1+I*a*eta)^n*(1+I*b*eta^2)^m*(1-I*a*conjugate(eta))^n*(1-I*b*conjugate(eta)^2)^m+abs(-1+I*a*eta)^(2*n)*abs(I*b*eta^2-1)^(2*m))
r2 := 1-I*delta(r1, n)
1-I*((2*I)*(1+I*a*eta)^(n+1)*(1+I*b*eta^2)^m*conjugate((1-I*a*eta)^(n+1)*(1-I*b*eta^2)^m)/((1+I*a*eta)^(n+1)*(1+I*b*eta^2)^m*(1-I*a*conjugate(eta))^(n+1)*(1-I*b*conjugate(eta)^2)^m+abs(-1+I*a*eta)^(2*n+2)*abs(I*b*eta^2-1)^(2*m))-(2*I)*(1+I*a*eta)^n*(1+I*b*eta^2)^m*conjugate((1-I*a*eta)^n*(1-I*b*eta^2)^m)/((1+I*a*eta)^n*(1+I*b*eta^2)^m*(1-I*a*conjugate(eta))^n*(1-I*b*conjugate(eta)^2)^m+abs(-1+I*a*eta)^(2*n)*abs(I*b*eta^2-1)^(2*m)))
exp_expr := subs({(1+I*b*eta^2)^m = exp(I*eta^2*t)}, r2)
1-I*((2*I)*(1+I*a*eta)^(n+1)*exp(I*eta^2*t)*conjugate((1-I*a*eta)^(n+1)*(1-I*b*eta^2)^m)/((1+I*a*eta)^(n+1)*exp(I*eta^2*t)*(1-I*a*conjugate(eta))^(n+1)*(1-I*b*conjugate(eta)^2)^m+abs(-1+I*a*eta)^(2*n+2)*abs(I*b*eta^2-1)^(2*m))-(2*I)*(1+I*a*eta)^n*exp(I*eta^2*t)*conjugate((1-I*a*eta)^n*(1-I*b*eta^2)^m)/((1+I*a*eta)^n*exp(I*eta^2*t)*(1-I*a*conjugate(eta))^n*(1-I*b*conjugate(eta)^2)^m+abs(-1+I*a*eta)^(2*n)*abs(I*b*eta^2-1)^(2*m)))
plot3d(abs(exp_expr), n = -5 .. 5, t = -5 .. 5, eta = 1+I)
Error, (in plot3d) unexpected option: eta = 1+I
Download soldis.mw
