Question: Error, (in RootFinding:-RSGateway:-refine_uni_tri) invalid input: RootFinding:-RSGateway:-try_refine_iso_tri expects its 1st argument, box, to be of type nonemptylist([rational, rational]), but received
I would like to get a (necessary and sufficient) condition on real parameters a, b, and c for which there exists (at least) one non-negative solution to 9*x**4 + c < 9*a*(x - 1) + 3*b*(x**2 - 1) + c*x**3.
A convenient way to formulate this is using quantifiers. Unfortunately, if I run
QuantifierElimination:-QuantifierEliminate(:-exists([x],:-And(x>=0,9*x^4+c<9*a*(x-1)+3*b*(x^2-1)+c*x^3)));
Maple will simply output
Error, (in RootFinding:-RSGateway:-refine_uni_tri) invalid input: RootFinding:-RSGateway:-try_refine_iso_tri expects its 1st argument, box, to be of type nonemptylist([rational, rational]), but received [8019*x^2+(-9*v__2^2-96552*v__2-279834912)*x+49*v__2^3+78318*v__2^2-387436932*v__2+121801800168, v__2^4+2052*v__2^3-5536296*v__2^2+3575222064*v__2-710903793888]
As an alternative method, one can execute
RealDomain:-solve([x >= 0, 9*x**4 + c < 9*a*(x - 1) + 3*b*(x**2 - 1) + c*x**3], 'parameters' = {a, b, c});
Regretfully, this time the computation is not done in several minutes (so one may have to abort it manually).
So, what is the proper approach to the above problem in Maple (without any a priori knowledge, if possible)?
