Question: Basic question on solve and extra solutions
Maple gives solutions that do not satisfy the equation. Wondering what do I need to change.
n:=3;m:=2;
eqx:=x^(n/m)=a;
maple_sol:=[PDEtools:-Solve(eqx,x)]; #also tried solve()
F:=map(X->eval(eqx,X),maple_sol);
map(X->evalb(X),F);
I always verified in Mathematica
Any thought what is going on and what do I need to change in my Maple code to make it give the solution x=a^(2/3) only?
It is also possible that Mathematica is the one who is skipping the two complex solutions, but then I need to verify these in Maple, and so far I can't. Only the first solution is verified by Maple.
Even simplification with assuming a>0 do not verify these two extra solution given with complex values. I also tried RealDomain package but this also had no effect. I tired assuming real also and tried simplify with symbolic option.
Anything else I should try?
Maple 2024 on windows 10
update
As I said, I tried RealDomain but with PDEtools:-Solve. With solve it works. Is this a bug? worksheet below
35788
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1701. The version installed in this computer is 1693 created 2024, March 7, 17:27 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib\`
n:=3;m:=2;
eqx:=x^(n/m)=a;
use RealDomain in (PDEtools:-Solve(eqx,x)) end use;
F:=map(X->eval(eqx,X),[%]);
map(X->evalb(X),F);
3
2
x^(3/2) = a
x = a^(2/3), x = (1/4)*a^(2/3)*(1+I*3^(1/2))^2, x = (1/4)*a^(2/3)*(I*3^(1/2)-1)^2
[a = a, (1/16)*4^(1/2)*(a^(2/3)*(1+I*3^(1/2))^2)^(3/2) = a, (1/16)*4^(1/2)*(a^(2/3)*(I*3^(1/2)-1)^2)^(3/2) = a]
[true, false, false]
n:=3;m:=2;
eqx:=x^(n/m)=a;
use RealDomain in (solve(eqx,x)) end use;
F:=map(X->eval(eqx,x=X),[%]);
map(X->evalb(X),F);
3
2
x^(3/2) = a
a^(2/3)
[a = a]
[true]
Download real_domain_solve_vs_PDEtools_Solve.mw
