Question: On using StringTools:-RegSubs
I never used Maple's StringTools:-RegSubs before.
I have a Latex string generated by Maple that has this form
"......    \\textrm{ ......   }  .... "
Where the dots mean anything, including space characters.  I need to change the part of the string  "\\textrm{ ...... }" to this
"......  \\begin{minipage}{\\linewidth}\\textrm{  ......   }\\end{minipage}  .... "
It is easy to change the opening part. Here is an example
s:="A& B& \\textrm{The fundamental matrix has } &C ";
s:=StringTools:-SubstituteAll(s,"\\textrm{","\\begin{minipage}{\\linewidth}\\textrm{");
Gives
The problem is how to replace the closing "}"  with "}\\end{minipage}".   I can't just replace "}" with "}\\end{minipage}" using SubstituteAll because I need to only change the "}" that closes the corresponding "\\textrm{" and not any other "}" that could be in the string.
So I need to use pattern matching or regular expression substitutions. The examples in help are not easy to understand.
Basically I need regular expression that matches
                        "\\textrm{ WILDCARD * }"
and change it to
                        "\\begin{minipage}{\\linewidth}\\textrm{ WILDCARD * }\\end{minipage}"
Any one know how to use Maple's egular expression to do this substitution using the above example?
Maple 2024 on windows 10.
Update
Thanks for the replies. I ended up writing small function that simply scan the string and do the replacement.
