Question: helping fsolve()?
I am using fsolve() to solve a highly nonlinear system of 6 equations in 6 variables: lambda_d1, lambda_i1, lambda_d2, lambda_i2, lambda_d3, lambda_i3.
fsolve() doesn't "solve"! I usually help fsolve() with some initial conditions and with the expected signs of the solution but in this case it's not enough. I noticed that if I comment out the expected signs line (that is, if I don't impose my 6 lambdas to be strictly positive), the fsolve() works.
How do I help fsolve() to pin down only positive solutions at each iteration? I have no reasons to believe that there aren't any positive solutions for all 6 lambdas...
Worksheet: fsolve_help.mw
thank you.
