Question: strange odetest result. Is this valid?
Is the following valid result from odetest? is returns 0^n when 0 was expected.
Is this a bug or valid result? Maple solution is correct, so I expected 0 only not 0^n as result.
25748
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1756 and is the same as the version installed in this computer, created 2024, June 5, 19:39 hours Pacific Time.`
ode:=diff(y(x), x)^n = 0
(diff(y(x), x))^n = 0
sol:=dsolve(ode)
y(x) = c__1
odetest(sol,ode)
0^n
odetest(sol,ode) assuming n::real
0^n
odetest(sol,ode) assuming n>0
0^n
Download strange_odetest_result_june_6_2024.mw
Update
Until this bug is fixed, I added the following to my code which checks for odetest result. it looks for 0^anything and changes it to 0.
ode:=diff(y(x), x)^n= 0;
sol:=dsolve(ode);
stat:=odetest(sol,ode);
if patmatch(stat,0^a::anything) then 0; else stat; fi
gives    0
I found this problem when using odetest to check mysolution for this ode and was not getting 0 as expected,.
