Question: why Maple gives same solution for two different equations?
Maple gives same solution for two different equations.
eq1 := 1/5*sqrt(-20*y + 1) - 1/5*ln(1 + sqrt(-20*y + 1)) = x + 2;
eq2 := -1/5*sqrt(-20*y + 1) - 1/5*ln(1 - sqrt(-20*y + 1)) = x + 2;
Solving these for y, gives same exact solution. But this is not correct. As this worksheet shows.
Is this a bug? How could two different equations give same solution?
15172
Case 1. Solve first then plugin x value in solution
eq1:=(sqrt(a^2 - 4*b*y) - a*ln(a + sqrt(a^2 - 4*b*y)))/b=x+c__1;
eq2:=(-sqrt(a^2 - 4*b*y) - a*ln(a - sqrt(a^2 - 4*b*y)))/b=x+c__1;
eq1:=eval(eq1,[a=1,b=5,c__1=2]);
eq2:=eval(eq2,[a=1,b=5,c__1=2]);
((a^2-4*b*y)^(1/2)-a*ln(a+(a^2-4*b*y)^(1/2)))/b = x+c__1
(-(a^2-4*b*y)^(1/2)-a*ln(a-(a^2-4*b*y)^(1/2)))/b = x+c__1
(1/5)*(-20*y+1)^(1/2)-(1/5)*ln(1+(-20*y+1)^(1/2)) = x+2
-(1/5)*(-20*y+1)^(1/2)-(1/5)*ln(1-(-20*y+1)^(1/2)) = x+2
sol1:=simplify(solve(eq1,y));
-(1/20)*LambertW(-exp(-11-5*x))*(LambertW(-exp(-11-5*x))+2)
sol2:=simplify(solve(eq2,y));
eval(sol1,x=10.);
0.3221340286e-27
eval(sol2,x=10.);
0.3221340286e-27
Case 2. Plugin in same x value in equation and then solve, we get different answers
eq1:=eval(eq1,[a=1,b=5,c__1=2,x=10]);
eq2:=eval(eq2,[a=1,b=5,c__1=2,x=10]);
(1/5)*(-20*y+1)^(1/2)-(1/5)*ln(1+(-20*y+1)^(1/2)) = 12
-(1/5)*(-20*y+1)^(1/2)-(1/5)*ln(1-(-20*y+1)^(1/2)) = 12
sol1:=evalf(solve(eq1,y));
-205.8850616
sol2:=evalf(solve(eq2,y));
0.3221340286e-27
Download different_equations_give_same_solution_june_12_2024.mw
