Question: arcsecond versus arcsecant
Is there a way to reassign the arcsecant function "arcsec()" as "asec()" so that "arcsec" can be assigned to the arcsecond unit "Unit(arcsec)"?
Ideally, I would like all of the inverse trigonometric functions to use the shorter notation "asec()" instead of "arcsec()".  I usually do this as aliases, i.e. "alias(asin = arcsin) : alias(asec = arcsec) :" but this won't allow reusing "arcsec" for a unit instead.
Example error for Maple 2023:
AddUnit(astronomical_unit, context = astronomy, default = true, prefix = SI, conversion = 149597870700*m) : # https://en.wikipedia.org/wiki/astronomical_unit
AddUnit(second, context = angle, spelling = arcsecond, plural = arcseconds, symbol = arcsec, prefix = SI_negative) :
AddUnit(parsec, context = astronomy, default = true, prefix = SI, conversion = AU/tan(arcsec)) ; # https://en.wikipedia.org/wiki/Parsec#Calculating_the_value_of_a_parsec
"Pi/648000" has to be used instead of "arcsec" here when defining the parsec since "arcsec" is already reserved for the arcsecant function, even with "alias(asec = arcsec) ;".
Correction: it looks like the parsec was redefined by the IAU in 2012 as exactly "648000*AU/Pi" without any tangents (or sines) in the definition (so the angle subtended by 1 AU at 1 PC is actually 0.999999999992" not 1").  Both "astronomical_unit" and "parsec" have the wrong values in Maple 2023 which need to be corrected manually.  But the conflict between arcseconds and arcsecants remains the same.
https://iau.org/static/resolutions/IAU2015_English.pdf
https://iopscience.iop.org/article/10.3847/0004-6256/152/2/41
