Question: why dsolve gives division by zero on this ode?
I do not have earlier Maple version to check now. But Maple 2024.1 gives division by zero on this second order ode with missing x. This looks like new problem in Maple. Would someone who have access to earlier version of Maple be able to check if this problem shows there also? I solved this and get y=x+3 as solution which Maple verifies.
ode:=diff(y(x),x$2)=(diff(y(x),x))^3-(diff(y(x),x))^2;
IC:=y(0)=3,D(y)(0)=1;
diff(diff(y(x), x), x) = (diff(y(x), x))^3-(diff(y(x), x))^2
y(0) = 3, (D(y))(0) = 1
dsolve([ode,IC])
Error, (in dsolve) numeric exception: division by zero
sol:=y(x)=3+x;
odetest(sol,[ode,IC])
y(x) = 3+x
[0, 0, 0]
DEtools:-odeadvisor(ode);
[[_2nd_order, _missing_x], [_2nd_order, _reducible, _mu_y_y1]]
infolevel[dsolve]:=5;
5
dsolve([ode,IC])
Methods for second order ODEs:
--- Trying classification methods ---
trying 2nd order Liouville
trying 2nd order WeierstrassP
trying 2nd order JacobiSN
differential order: 2; trying a linearization to 3rd order
--- trying a change of variables {x -> y(x), y(x) -> x}
trying 2nd order ODE linearizable_by_differentiation
trying 2nd order, 2 integrating factors of the form mu(x,y)
trying differential order: 2; missing variables
-> Computing canonical coordinates for the symmetry [0, 1]
-> Rewriting ODE in canonical coordinates by means of differential invariants
Try computing 1 more symmetries for ODE written in canonical coordinates
 -> Computing symmetries using: way = 3
 Found another symmetry:
[1, 0]
[-x+y, 0]
Computing a convenient ordering to use the 3 symmetries available
<- differential order: 2; canonical coordinates successful
<- differential order 2; missing variables successful
dsolve(ode)
[1, 0]
[-x+y, 0]
-> Calling odsolve with the ODE diff(_b(_a) _a) = _b(_a)^3-_b(_a)^2 _b(_a) HINT = [[1 0] [-_a+y -_b*(_b-1)]]
   *** Sublevel 2 ***
   symmetry methods on request
 1st order, trying reduction of order with given symmetries:
[1, 0], [-_a+y, -_b*(_b-1)]
   1st order, trying the canonical coordinates of the invariance group
   <- 1st order, canonical coordinates successful
y(x) = ln(LambertW(-c__1*exp(x-1)))+c__2
Download divide_by_zero_maple_2024_1_august_5_2024.mw
