Question: Typesetting internal error when Physics update is not on libname path. How to avoid?
[moderator: The Physics update Library fixes this bug with the same error generated and reported by the same Mapleprimes member on another ODESteps example.]
I have removed Physics update from libname path.
Now I find I get error calling latex command. When Physics update is on libname, no error.
The error is
         Error, (in Typesetting:-Parse) too many levels of recursion
I am using worksheet with typesetting extended. But also when I change it to typesetting standard, same error.
Does this mean one must keep Physics update on libname path for Maple to work OK?
Is this error expected if Physics update is not on libname?
Worksheet below that shows this problem
CASE 1. With Physics update in libname path, no error
libname;
ode:=[diff(x__1(t),t)=2*x__1(t)+x__2(t),diff(x__2(t),t)=2*x__1(t)+3*x__2(t)];
[diff(x__1(t), t) = 2*x__1(t)+x__2(t), diff(x__2(t), t) = 2*x__1(t)+3*x__2(t)]
the_output:=Student:-ODEs:-ODESteps(ode,output=typeset):
latex(the_output,'output'=string):
CASE 2.  Removing Physics from libname path, gives internal error
libname:=libname[2];
"C:\Program Files\Maple 2024\lib"
Download internal_error_from_latex_when_libname_changed_nov_2_2024.mw
