Question: Error, (in PDEtools:-Solve) found functions with same name, but works OK in solve
Is this a known error when using PDEtools:-Solve? I get no error using solve on same input, so thought to ask, just in case it should not happen.
For now, I will change my code to use solve for this.
I am basically solving two equations in Laplace domain for Y1(s) and Y2(s). But since there are initial conditions x(0) and y(0) in the equations, and Laplace has L(x(t),t,s)  then PDEtools:-Solve is not happy, as it sees x(t) and x(0) in same input.
But solve has no problem with this. Who is correct? solve or Solve?
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1828 and is the same as the version installed in this computer, created 2024, November 18, 7:25 hours Pacific Time.`
libname;
sys:=[s*laplace(x(t),t,s)-x(0) = -3*laplace(x(t),t,s)+4*laplace(y(t),t,s)+1/(s^2+1), s*laplace(y(t),t,s)-y(0) = -2*laplace(x(t),t,s)+3*laplace(y(t),t,s)+1/s^2];
Ys:=[laplace(x(t),t,s), laplace(y(t),t,s)];
[s*laplace(x(t), t, s)-x(0) = -3*laplace(x(t), t, s)+4*laplace(y(t), t, s)+1/(s^2+1), s*laplace(y(t), t, s)-y(0) = -2*laplace(x(t), t, s)+3*laplace(y(t), t, s)+1/s^2]
[laplace(x(t), t, s), laplace(y(t), t, s)]
solve(sys,Ys);
[[laplace(x(t), t, s) = (x(0)*s^5+4*y(0)*s^4-3*x(0)*s^4+x(0)*s^3+4*y(0)*s^2-3*x(0)*s^2+s^3+s^2+4)/((s^4-1)*s^2), laplace(y(t), t, s) = (y(0)*s^5+3*y(0)*s^4-2*x(0)*s^4+y(0)*s^3+3*y(0)*s^2-2*x(0)*s^2+s^3+s^2+s+3)/((s^4-1)*s^2)]]
PDEtools:-Solve(sys,Ys)
Error, (in PDEtools:-Solve) found functions with same name but depending on different arguments in the given DE system: x(0), x(t). Specification of the dependent variables is required
Download differenece_between_solve_and_Solve_nov_20_2024.mw
