Question: How to do change of variable in ode using z=g(x)
What is the correct syntax to do this change of variable from the text book:
The problem is that using PDEtools:-dchange, it wants the transformation to have form { old = new}, i.e. x=...  so I can not write  z=g(x) in the transformation.
For example
ode:= diff(y(x),x$2)+diff(y(x),x)+y(x)=sin(x);
PDEtools:-dchange({z= g(x)},ode,known={x},unknown={z});
Error, (in dchange/info) missing a list with the new variables
And if I first solve for x so that I can write the transformation with x on left side, it still does not work
PDEtools:-dchange({x=RootOf(g(_Z) - z)},ode,known={x},unknown={z});
Where RootOf(g(_Z) - z) was result of solve(z=g(x),x);
I am sure this can be done in Maple, I just do not know the right syntax to use with dchange.
Maple 2024.2
