Question: simultaneous animation of center of a circle moving along a path and circle radius decreasing
Given the center x1 of a circle in R^2 with radius d12, and a point p2 on the circle, so that d12=||p2-x1||, denote the points on the line segment from x1 to p2 as x1(t) = x1+t*v12, with t=0..d12, and v12 =( p2-x1)/d12.  I want to animate the points x1(t) moving along the line segment from x1 to p2 and the corresponding circles of decreasing radius, with center x(t) and radius d12-t, so that p2 remains on the circle.
I can animate the points along the line segment from x1 to p2 using ‘style=point, symbol=solidcircle’.
I would like to use plottools-circle, to plot the circles. I have also tried the following type commands for the circles of decreasing radius.
Plot([x1(1)+t*v12(1)+(d12-t)*cos(theta)*v12(1)+ (d12-t)*sin(theta)*u12(1), x1(2)+ +t*v12(2)+(d12-t)*d12*cos(theta)*v12(2)+(d12-t)*sin(theta)*u12(2), theta=0..2*PI]
where u12 is a unit vector orthogonal to v12.
I have not been able to combine the two plots into an animation. Thank you
