Question: Bug report: Error, (in dsolve) invalid subscript selector
I do not remember if I reported this before or not. Can't find it. Just in case, I am posting this.
If someone find it is duplicate, feel free to delete this. But this is in latest Maple 2024.2. May be this can be fixed in time by Maple 2025 version.
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1840 and is the same as the version installed in this computer, created 2024, December 2, 10:11 hours Pacific Time.`
libname;
ode := diff(y(x),x)/y(x)-(3*(4*x^2+y(x)^2+1))/(2*x*(4*x^2+y(x)^2-2-2*x))=0;
(diff(y(x), x))/y(x)-(3/2)*(4*x^2+y(x)^2+1)/(x*(4*x^2+y(x)^2-2-2*x)) = 0
DEtools:-odeadvisor(ode);
[_rational]
dsolve(ode,y(x));
infolevel[dsolve]:=5;
5
ode := diff(y(x),x)/y(x)-(3*(4*x^2+y(x)^2+1))/(2*x*(4*x^2+y(x)^2-2-2*x))=0:
dsolve(ode,y(x));
Methods for first order ODEs:
--- Trying classification methods ---
trying a quadrature
trying 1st order linear
trying Bernoulli
trying separable
trying inverse linear
trying homogeneous types:
trying Chini
differential order: 1; looking for linear symmetries
trying exact
Looking for potential symmetries
trying inverse_Riccati
trying an equivalence to an Abel ODE
equivalence obtained to this Abel ODE: diff(y(x),x) = 3/2*(4*x^2+1)/x/(2*x^2-x-1)*y(x)-(x^2+2*x+3)/x/(2*x^2-x-1)^2*y(x)^2+3/8*(2*x+3)/(2*x^2-x-1)^3/x*y(x)^3
trying to solve the Abel ODE ...
The relative invariant s3 is: -1/432*(8*x^4+40*x^3+45*x^2-270*x+135)/x^3/(x-1)^6/(2*x+1)^4
The first absolute invariant s5^3/s3^5 is: 729/16*(128*x^8+1152*x^7+3696*x^6+1744*x^5+8148*x^4-31500*x^3+6615*x^2-5670*x+8505)^3/(2*x+1)^4/(8*x^4+40*x^3+45*x^2-270*x+135)^5
The second absolute invariant s3*s7/s5^2 is: 1/3*(8*x^4+40*x^3+45*x^2-270*x+135)*(10240*x^12+133120*x^11+697600*x^10+1710080*x^9+3358592*x^8-1701568*x^7+6692592*x^6-18182448*x^5+2088072*x^4-7938000*x^3+2525985*x^2+1786050*x+2679075)/(128*x^8+1152*x^7+3696*x^6+1744*x^5+8148*x^4-31500*x^3+6615*x^2-5670*x+8505)^2
...checking Abel class AIL (45)
...checking Abel class AIL (310)
...checking Abel class AIR (36)
...checking Abel class AIL (301)
...checking Abel class AIL (1000)
...checking Abel class AIL (42)
...checking Abel class AIL (185)
...checking Abel class AIA (by Halphen)
...checking Abel class AIL (205)
...checking Abel class AIA (147)
...checking Abel class AIL (581)
...checking Abel class AIL (200)
...checking Abel class AIL (257)
...checking Abel class AIL (400)
...checking Abel class AIA (515)
...checking Abel class AIR (1001)
...checking Abel class AIA (201)
...checking Abel class AIA (815)
... changing x -> 1/x, trying again
The third absolute invariant s5*s7/s3^4 is: 243/16*(10240*x^12+133120*x^11+697600*x^10+1710080*x^9+3358592*x^8-1701568*x^7+6692592*x^6-18182448*x^5+2088072*x^4-7938000*x^3+2525985*x^2+1786050*x+2679075)/(2*x+1)^4*(128*x^8+1152*x^7+3696*x^6+1744*x^5+8148*x^4-31500*x^3+6615*x^2-5670*x+8505)/(8*x^4+40*x^3+45*x^2-270*x+135)^4
 ->             ...checking Abel class D (by Appell)
 -> Step 1: checking for a disqualifying factor on F after evaluating x at a number
Trying x = 2
*** No disqualifying factor on F was found ***
 -> Step 2: calculating resultants to eliminate F and get candidates for C
*** Candidates for C are {4/27} ***
 -> Step 3: looking for a solution F depending on x
*** No solution F of x was found ***
 ->             ...checking Abel class B (by Liouville)
Trying x = 2
*** Candidates for C are {1, 4, 1/4} ***
 ->             ...checking Abel class A (by Abel)
Trying x = 2
*** Candidates for C are {0, -1/4} ***
 ->             ...checking Abel class C (by Abel)
Trying x = 2
*** Candidates for C are {2, -11676447873119/75975070592769, 9/5, 15632211369872/75439744512117, 46273613050865/52325357771027, 75312059745574/25138886548531} ***
_____________________________
C = 9/5 leads to a useless solution (F does not depend on x)
 ->             ...checking Abel class AIL 1.6
Trying x = 2
*** Candidates for C are {-4, 16} ***
 ->             ...checking Abel class AIL 1.8
Trying x = 2
*** Candidates for C are {0, -116457391291688/45108305127449, -96869842492381/35485755507516, -36964550865207/94238117721032, -32286830321303/11596568583712, 32286830321303/11596568583712, 36964550865207/94238117721032, 96869842492381/35485755507516, 116457391291688/45108305127449} ***
 ->             ...checking Abel class AIL 1.9
Trying x = 2
*** Candidates for C are {-2/9, -1/9} ***
 ->             ...checking Abel class AIA 1.51
Trying x = 2
*** Candidates for C are {0, -94917840318055/84247876515289, -85939756880989/51399391393709, -82210125508529/36853933366676, -74381886667083/82545981233858, -41168492684238/33804146399567, -15658703496425/19275443365317, -9175348901453/101481647952193, 3/4, 15/4, 5568553686203/113599855351490, 12774469621703/63437040534358, 17836021821409/102823494563886, 39657708622139/74009717243016, 82495450887526/27663991325651, 86656182727564/45157560524183, 90074893410229/54954593917906, 100200889070747/32282555481919, 113612565327585/103754255779069} ***
C = 15/4 leads to a useless solution (F does not depend on x)
Trying x = 2
*** Candidates for C are {-1, 1, -113553630998996/78694251194667, -112790344818825/35834119404842, -104905620984375/18860524785743, -95409943222181/78810323073434, -77648002983645/31218435062578, -67259194033608/9576982470445, -46892223838816/86694928762723, -45901561561111/29768419326991, -34674701564566/6522678435631, 26154715634141/21099761863911, 42841215778132/81925179545457, 52638927823233/15127919203723, 54069389554571/5444364811188, 54445812264368/10328928623117, 56815569067370/40738034746481, 75614540760757/62881656939350, 76459718737483/64786816765621, 85896394925571/88677987470966, 90623073438172/24246571690325, 103628692054633/17857341616628, 117754725919014/60191028908095} ***
C = -1 leads to a useless solution (F does not depend on x)
C = -113553630998996/78694251194667 leads to a useless solution (F does not depend on x)
C = -112790344818825/35834119404842 leads to a useless solution (F does not depend on x)
C = -104905620984375/18860524785743 leads to a useless solution (F does not depend on x)
C = -95409943222181/78810323073434 leads to a useless solution (F does not depend on x)
C = -77648002983645/31218435062578 leads to a useless solution (F does not depend on x)
C = -67259194033608/9576982470445 leads to a useless solution (F does not depend on x)
C = -46892223838816/86694928762723 leads to a useless solution (F does not depend on x)
C = -45901561561111/29768419326991 leads to a useless solution (F does not depend on x)
C = -34674701564566/6522678435631 leads to a useless solution (F does not depend on x)
C = 26154715634141/21099761863911 leads to a useless solution (F does not depend on x)
C = 42841215778132/81925179545457 leads to a useless solution (F does not depend on x)
C = 52638927823233/15127919203723 leads to a useless solution (F does not depend on x)
C = 54069389554571/5444364811188 leads to a useless solution (F does not depend on x)
C = 54445812264368/10328928623117 leads to a useless solution (F does not depend on x)
C = 56815569067370/40738034746481 leads to a useless solution (F does not depend on x)
C = 75614540760757/62881656939350 leads to a useless solution (F does not depend on x)
C = 76459718737483/64786816765621 leads to a useless solution (F does not depend on x)
C = 85896394925571/88677987470966 leads to a useless solution (F does not depend on x)
C = 90623073438172/24246571690325 leads to a useless solution (F does not depend on x)
C = 103628692054633/17857341616628 leads to a useless solution (F does not depend on x)
C = 117754725919014/60191028908095 leads to a useless solution (F does not depend on x)
 ->             ...checking Abel class AIA 1.52
Trying x = 2
*** Candidates for C are {-5, -4, -3, 0, 1, 2, -3/2} ***
 ->             ...checking Abel class AIA 1.53
Trying x = 2
*** Candidates for C are {-3, -1, 1, 2, -3/2, -2/3, -1/2} ***
C = -3 leads to a useless solution (F does not depend on x)
C = -3/2 leads to a useless solution (F does not depend on x)
trying to map the Abel into a solvable 2nd order ODE
...checking Abel class AIA 2-parameter, reducible to Riccati
dsolve(ode,y(x));
tracelast;
Download dsolve_invalid_subscript_dec_27_2024.mw
