Question: How do I prevent the disappearance of backslash?
Consider the following:
MyTableElement1 := proc(L::list(nonnegint))
  ## L will have only two elements
  local M, x, y;
  M:=L;
  x:=convert(M[1],string);
  y:=convert(M[2],string);
  return cat("\\begin{tabular}{c} ",x," \\\\ ",y," \\end{tabular}")
end;
MyTableElement1([2,3]);
will output
"\begin{tabular}{c} 2 \\ 3 \end{tabular}"
as desired. However, if one inserts an \hline into the table,
MyTableElement2 := proc(L::list(nonnegint))
  local M, x, y;
  M:=L;
  return cat("\\begin{tabular}{c} ",x," \\\\ \\hline ",y," \\end{tabular}")
end;
will output
"\begin{tabular}{c} 2 \\ \hline 3 \end{tabular}"
again as desired. However, if I copy and paste this int a document, I get
"\begin{tabular}{c} 2 \\ hline 3 \end{tabular}".
Note that \hline is now just hline. Putting "\\\\" in front of the hline outputs
"\begin{tabular}{c} 2 \\ \\hline 3 \end{tabular}",
but this does not compile properly. How can I get a proper \hline command to appear in the table? Thank uou for your consideration.
