Question: Why when do transform the equation to latex the place of term are change?
when i use change maple to latex most of that equation when i want to change the place of term are change how i can fix that for example in (R) if watch in exponential the x is first term but after changing to latex are change which i have to change by hand how i can fix this issue?
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
_local(gamma)
Warning, A new binding for the name `gamma` has been created. The global instance of this name is still accessible using the :- prefix, :-`gamma`.  See ?protect for details.
undeclare(prime)
declare(u(x, y, z, t))
u(x, y, z, t)*`will now be displayed as`*u
declare(f(x, y, z, t))
f(x, y, z, t)*`will now be displayed as`*f
W := Lambda = k[i]*(t*w[i]+y*l[i]+z*r[i]+x)+eta[i]
latex(W)
\Lambda = k_{i} \left(w_{i} t +y l_{i}+r_{i} z +x \right)+\eta_{i}
Lambda[1] := k[i]*(t*w[i]+y*l[i]+z*r[i]+x)+eta[i]
Q := f = 1+exp(Lambda[1])
f = 1+exp(k[i]*(t*w[i]+y*l[i]+z*r[i]+x)+eta[i])
Q1 := subs(W, Q)
latex(Q1)
f =
1+{\mathrm e}^{k_{i} \left(w_{i} t +y l_{i}+r_{i} z +x \right)+\eta_{i}}
eq15 := w[i] = (-1+sqrt(-4*beta*mu*l[i]-4*delta*mu*r[i]-4*mu*k[i]^2-4*alpha*mu+1))/(2*mu)
w[i] = (1/2)*(-1+(-4*beta*mu*l[i]-4*delta*mu*r[i]-4*mu*k[i]^2-4*alpha*mu+1)^(1/2))/mu
latex(eq15)
w_{i} =
\frac{-1+\sqrt{-4 \beta  \mu  l_{i}-4 \delta  \mu  r_{i}-4 \mu  k_{i}^{2}-4 \alpha  \mu +1}}{2 \mu}
R := f(x, y, z, t) = 1+exp(k[i]*(x+l[i]*y+r[i]*z+(-1+sqrt(-4*beta*mu*l[i]-4*delta*mu*r[i]-4*mu*k[i]^2-4*alpha*mu+1))*t/(2*mu))+eta[i])
f(x, y, z, t) = 1+exp(k[i]*((1/2)*(-1+(-4*beta*mu*l[i]-4*delta*mu*r[i]-4*mu*k[i]^2-4*alpha*mu+1)^(1/2))*t/mu+y*l[i]+r[i]*z+x)+eta[i])
latex(R)
f =
1+{\mathrm e}^{k_{i} \left(\frac{\left(-1+\sqrt{-4 \beta  \mu  l_{i}-4 \delta  \mu  r_{i}-4 \mu  k_{i}^{2}-4 \alpha  \mu +1}\right) t}{2 \mu}+y l_{i}+r_{i} z +x \right)+\eta_{i}}
Download latex.mw
