Question: workaround for Maple unable to verify its own solution for series?
I've reported this problem to Maple many years ago but still not fixed in Maple 2025.
Maple not able to verify its own solution on some series solutions using odetest.
Any one can suggest a workaround one can use other than odetest to verify ode solution when using series? Or have an idea why this happens?
The solution is correct but for some reason odetest returns FAIL
Below is one example of many I have
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1861 and is the same as the version installed in this computer, created 2025, April 10, 15:58 hours Pacific Time.`
ode:=x*diff(y(x),x$2)+y(x)=0;
IC:=y(0)=1;
maple_sol:=dsolve([ode,IC],y(x),'series');
odetest(maple_sol,[ode,IC],'series','point'=0);
x*(diff(diff(y(x), x), x))+y(x) = 0
y(0) = 1
y(x) = c__1*x*(series(1-(1/2)*x+(1/12)*x^2-(1/144)*x^3+(1/2880)*x^4-(1/86400)*x^5+O(x^6),x,6))+ln(x)*(series(-x+(1/2)*x^2-(1/12)*x^3+(1/144)*x^4-(1/2880)*x^5+O(x^6),x,6))+(series(1-(3/4)*x^2+(7/36)*x^3-(35/1728)*x^4+(101/86400)*x^5+O(x^6),x,6))
Warning, unable to compute series necessary to test the given solution
FAIL
Download series_unable_to_odetest_april_12_2025.mw
