Question: How do I avoid automatically generated new variable names by the StateSpace and the FeedbackConnect commands?
Dear Maple experts,
I try to avoid the generation of new variable names (for states, inputs, outputs) introduced automatically by maple (StateSpace(), FeedbackConnect()) in the two (connected) cases:
1)
I generated a discrete StateSpace system using a difference equation:
sys2 := StateSpace([u(n)=K_virt*(q_a(n)-q_d)+D_virt*(q_a(n)-q_a(n-1))/T],inputvariable=[q_a(n)],outputvariable=[u(n)],discrete=true,sampletime=T);
The statevariable "x1(n)" is automatically generated by maple
I tried to avoid this by using the following commands that don't work:
Try 1:
sys2 := StateSpace([u(n)=K_virt*(q_a(n)-q_d)+D_virt*(q_a(n)-q_a(n-1))/T],inputvariable=[q_a(n)],outputvariable=[u(n)],statevariable=[q_a(n-1)],discrete=true,sampletime=T);
-> error message:
Error, (in ProcessOptions) argument 'statevariable = [q_a(n-1)]' invalid: rhs should be of type list({name, anyfunc(name)})
Try 2:
sys2 := StateSpace([u(n)=K_virt*(q_a(n)-q_d)+D_virt*(q_a(n)-q_a(n-1))/T],inputvariable=[q_a(n)],outputvariable=[u(n)],statevariable=[q_a_delayed],discrete=true,sampletime=T);
-> error message:
Error, (in DynamicSystems:-StateSpace) missing state(s): {q_a_delayed(n)}
Try 3:
sys2 := StateSpace([u(n)=K_virt*(q_a(n)-q_d)+D_virt*(q_a(n)-q_a(n-1))/T],inputvariable=[q_a(n)],outputvariable=[u(n)],statevariable=[q_a_delayed(n)],discrete=true,sampletime=T);
-> error message:
Can you help me here?
2)
I have two discrete StateSpace models (sys1, sys2):
* sys2 is the one from above (1 input, 1 output, 1 state)
* sys1 (2 inputs, 4 outputs, 4 states) doesn't contain any automatically generated variables (I obtained this one by transforming a continuous statespace model to a discrete one)
* variables that represent the same signal have the same name in both systems.
   -> "q_a(n)" appears as an output in sys1 and as an input in in sys2
   -> "u(n)"     appears as an input in sys1 and as an output in in sys2
Now I combined these two models via:
FeedbackConnect([sys1, sys2],[[2,2,1,-1]])
Instead of using the variable names I introduced maple generates new variable names for inputs, outputs and states.
How can I avoid this?
(the option "merge=evaluate") seems not to work (even if I work with numeric values for the system parameters instead of symbols)
Thank you in advance!
