Question: another odetest challenge
This solution by dsolve is correct. I get same solution. The problem is odetest does not give zero.
All my simplification attempts failed and adding assumptions to call to odetest does not change anything for what I tried. i.e. could not make Maple show that the result of odetest is zero.
Any one can come up with smart way to verify this solution is correct?
ode:=diff(y(x),x)*(x-ln(diff(y(x),x))) = 1;
maple_sol:=dsolve(ode);
(diff(y(x), x))*(x-ln(diff(y(x), x))) = 1
y(x) = -(1+LambertW(-exp(-x))*x+LambertW(-exp(-x))^2)/LambertW(-exp(-x))+c__1
the_residue:=odetest(maple_sol,ode);
(-x+ln(-1/LambertW(-1/exp(x)))-LambertW(-1/exp(x)))/LambertW(-1/exp(x))
Digits:=100;
plot(the_residue,x=0..10)
100
Download odetest_challange_may_15_2025.mw
Note that coulditbe(the_residue=0) gives true, but this is not reliable way to check, so this method does not coumt.
