Question: How to plot a vector with units and one without units
Dear Power Users,
This is probably a simple question for you but I am stuck. In the attached worksheet I would like to plot (the plot is called P5) a vector with units (mm) against a vector without units. This didn't work out, so I removed the units from the vector with units, and this plotted but after the conversion the numeric values are no longer in mm but inches. How can I correct this?
Thank you in advance for your time and willingness to help.
testSheetHorseShoe.mw
