Question: Maple Optimization Returning Lower Bound Instead of True Maximum
I'm optimizing a function with constraints, meaning the decision variable has both a lower and an upper bound. When I use the  (MAX) syntax in Maple, it returns the lower bound as the optimal value (Pc) along with the corresponding function value. However, when I plot the graph, it shows that the function actually reaches its maximum at the upper bound. What could be causing this discrepancy
Sheet:Q_result_1.mw
