Question: solve failing on second time called.
I've been debugging this for 20 hrs and finally able to make an example.
I noticed that solve() suddenly no longer works and times out.
First time calling solve() works. Second time it I see message
               Warning, solve may be ignoring assumptions on the input variables.
And it hangs.  Same exact code.   It has to do with calling odetest before and using Physics:-Setup('assumingusesAssume' = false):
i.e. this works
     odetest(...) assuming integer
     solve(....) #no hang
     odetest(....) assuming positive
But this does not work
     Physics:-Setup('assumingusesAssume' = true):
     solve(...)   #HANGS
Here is worksheet showing the problem. If I remove first call to odetest, solve do not hang.
Also removing Physics:-Setup('assumingusesAssume' = false):, solve also works OK. (ie. does not hang)
So it has to do with some internal caching which causes solve to stop working.
Can others reproduce this and can cause it and how to fix it so solve do not hang second time?
The input used below is not important. It is just what I found to cause this. One would expect solve() to work same way for same input all the time.
Also, same problem happens when using PDEtools:-Solve instead of solve. It hangs second time.
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1873 and is the same as the version installed in this computer, created 2025, May 18, 21:44 hours Pacific Time.`
SupportTools:-Version();
`The Customer Support Updates version in the MapleCloud is 20 and is the same as the version installed in this computer, created May 23, 2025, 23:34 hours Eastern Time.`
DEFINE input
ode:=y(x)*sqrt(1 + diff(y(x), x)^2) - a*y(x)*diff(y(x), x) - a*x = 0:
sol:=-_C4^2 + (-y(x)*sqrt(_C4^2/y(x)^2) + a*x)^2/a^2 + y(x)^2 = 0:
ode_to_test:=y(x)*(1+diff(y(x),x)^2)^(1/2)-a*y(x)*diff(y(x),x)-a*x = 0:
FIRST TIME solve works
    try
        timelimit(30,(odetest(sol,ode,y(x)) assuming integer));
    catch:
        NULL;
    end try:
    try
        timelimit(30,[solve(ode_to_test,diff(y(x),x))]);
        print("SOLVE worked");
    catch:
        print("WHY TIMED OUT??");
    end try:
    try
        timelimit(30, (odetest(sol,ode,y(x)) assuming positive) );
    catch:
        NULL;
    end try:
"SOLVE worked"
RUN SAME CODE AS ABOVE again, now it does not work
    try
    catch:
        NULL;
    end try:
    try
    catch:
    end try:
    try
    catch:
        NULL;
    end try:
"WHY TIMED OUT??"
Download why_solve_stops_working_maple_2025_may_28_2025.mw
This worksheet below shows that by removing Physics:-Setup('assumingusesAssume' = false): now solve works OK second time. (I turn on/off Physics:-Setup('assumingusesAssume' since I found sometimes it can help with odetest to turn it off in some other cases. But now I am scared of touching this setting as it seems to have side effects internally)
Physics:-Version();
DEFINE input
    try
    catch:
        NULL;
    end try:
    try
    catch:
    end try:
    try
    catch:
        NULL;
    end try:
"SOLVE worked"
    try
    catch:
        NULL;
    end try:
    try
    catch:
    end try:
    try
    catch:
        NULL;
    end try:
"SOLVE worked"
Download why_solve_stops_working_maple_2025_may_28_2025_V2.mw
