Question: Kron Reduction from 8 port Yp matrix to 4 port Yp matrix
hello:
Problem Background
   I am using Maple to perform a symbolic derivation for analyzing a coupled stripline directional coupler (as illustrated in the figure) The objective is to start from the known 4-port admittance matrix Y4 of a single coupled-line section(figure (a)) and derive the resulting 4-port admittance matrix Y_T for the composite structure shown in figure (b).
Diagram Explanation (Refer to Attached Figure)
  • Figure (a) represents a standard 4-port coupled-line segment, with admittance matrix Y4. The port ordering is labeled in green as (1,2,3,4).
  • Figure (b) shows a composite network constructed by combining two identical Y4 structures, where:
    • The right block are renumbered as red labels (5–8), which differ from the default Y4 port ordering.
      • The middle section includes two shorted node pairs that merge the internal connections:
        • Ports 2 and 6 are connected to form internal node A. so we get equtions:I2=-I6,V2=V6
        • Ports 4 and 8 are connected to form internal node B.so we get equtions:I4=-I8,V4=V8
Modeling Objective
Using a matrix-based linear algebra approach, I aim to compute the effective 4-port admittance matrix Y_T for the final structure shown in Figure (b), with the active ports being 1, 3, 5, and 7.
Technical Procedure Breakdown
Step 1: Define the Basic Admittance Terms
The even-mode and odd-mode responses are expressed symbolically. From these, the basic admittance elements are defined:
  • Y0, Ym1, Ym2, Ym3 using Yoe, Yoo, and θ.
Step 2: Build the Original 4-Port Matrix Y4
Construct the 4×4 admittance matrix Y4 for the left-side coupled-line segment, using port ordering (1,2,3,4) as shown in Figure (a).
Step 3: Port Reordering for the Right Coupler
The Secondary (right-side) coupled-line block uses a different port order (Ports 5–6–7–8 correspond to the original 2–1–4–3).
Therefore, a permutation matrix P is introduced to reorder the ports as:
(1,2,3,4) → (2,1,4,3)
The reordered admittance matrix Y4_R is obtained via:
Y4_R := P . Y4 . Transpose(P)
Step 4: Construct the 8×8 Overall Admittance Matrix Y8
Using BlockDiagonalMatrix or equivalent logic, we assemble the composite 8×8 admittance matrix Y8, representing:
[1 2 3 4 | 5 6 7 8]
The left half corresponds to Y4, and the right half to Y4_R.
Step 5: Port Shorting (Node Merging)
According to the physical configuration:
  • Ports 2 and 6 are shorted to form Node A
  • Ports 4 and 8 are shorted to form Node B
We define a node-merging matrix S (6×8) to map the 8-port structure into a reduced 6-port structure using:
[1, 3, 7, 5, A(=2+6), B(=4+8)]
Apply the transformation:
Y6 := S . Y8 . Transpose(S)
Step 6: Submatrix Extraction and Kron Reduction
From the reduced matrix Y6, extract:
  • External port indices: E = [1, 2, 3, 4] → Ports 1, 3, 7, 5
  • Internal node indices: I = [5, 6] → Nodes A, B
Perform Kron reduction to eliminate internal nodes and obtain the final reduced matrix:
Y_T := Y_EE - Y_EI . Inverse(Y_II) . Y_IE
❗Current Issue / Question
When I try to execute:
Y8 := BlockDiagonalMatrix([Y4, Y4_R])
Maple does not return a usable or well-formed 8×8 matrix
❓What I need help with:
  1. How to correctly construct the block-diagonal matrix Y8 := BlockDiagonalMatrix([Y4, Y4_R]) so that it's recognized as an 8×8 matrix in Maple?
  2. Validate whether the full logic flow from Y4 → port mapping → block matrix → merging → Kron reduction is mathematically sound and correctly implemented, and get the final 4 port Y parameter matrix.
  3. If possible, please suggest any more stable or simplified alternative matrix operations for symbolic Kron reduction involving port reordering and node merging.
here is the maple file:
Download CoupleLine_WH2.mw
thank in advance for your help.
