Question: Is there any Alternative to Maplet for Presenting Results in a Table?
I am trying to display the results by substituting values into a table format after solving the KKT conditions. I attempted to do this using Maplet, but it did not give the desired output or flexibility.
Could you please guide me on:
  • The correct way to capture and display substituted results in a table?
  • Any alternative syntax or functions (other than Maplet) that are better suited for this purpose?
I would also like to confirm whether the substitution I made for the lower and upper bounds—specifically C_min value  and C_max value —has been done correctly. Could you please verify if this is the correct way to implement these bounds within the KKT formulation?
KKT_Table_Q-22.mw
