Question: are c__1 and _C1 no longer same object in Maple 2025.1?
The nice addition added to Maple 2022 in this  post made it clear that c__1 and _C1 are the same under the cover.
But then why in Maple 2025.1 it does not give this?
I found this when I was trying to find constants of integrations in solution of an ode, and used
                 indets(sol,And(symbol, suffixed(_C, nonnegint)));
Which did not find the constants of integration, since I happened to have typed the solution using c__1 and not _C1, but I thought they are the same.
Did something change or I still dont understand well the difference between c__1 and _C1 ?
Worksheet below.
SupportTools:-Version();
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1881 and is the same as the version installed in this computer, created 2025, October 7, 16:4 hours Pacific Time.`
sol:= y(x)=-cos(x)/2+sin(x)/2+c__1*exp(-x);
y(x) = -(1/2)*cos(x)+(1/2)*sin(x)+c__1*exp(-x)
indets(sol,And(symbol, suffixed(c__, nonnegint)));
{c__1}
sol:= y(x)=-cos(x)/2+sin(x)/2+_C1*exp(-x);
y(x) = -(1/2)*cos(x)+(1/2)*sin(x)+_C1*exp(-x)
{_C1}
c__1 - _C1
c__1-_C1
addressof(c__1);
36893628553737883996
addressof(_C1);
36893628553623934140
Download why_c1_and_C1_not_same_oct_19_2025.mw
Update
Found out why. This only works if one calls dsolve() first.  Here is an example
sol:=dsolve(diff(y(x),x)=x)
y(x) = (1/2)*x^2+c__1
c__1 - _C1;
{c__1}
my_sol:=y(x)=(x^2)/2+c__1;
c__1 - _C1;
c__1-_C1
indets(my_sol,And(symbol, suffixed(_C, nonnegint)));
Download why_c1_and_C1_not_same_oct_19_2025_V1.mw
But this is really confusing. c__1 before calling dsolve is not the same as c__1 after calling dsolve.
It will be better if Maple is changed such that these work the same all the time without having to call dsolve() first.
