I am able to reproduce a case where same exact code, which is in .mla library, when called from worksheet produces Maple internal errors when calling odetest, which happens at random places
Error, (in depends) too many levels of recursion
Error, (in anonymous procedure called from depends) too many levels of recursion
But when calling same exact proc in the mla from the command line using
/home/me/maple2025/bin/maple -q BUILD_ALL.mpl
Where BUILD_ALL.mpl has same command used in worksheet, which is say my_command() where my_command() is proc in my .mla library, the code runs with no erros.
Both worksheet and command use the same exact initialization code before running the command, which is read from this file
dsolve(diff(y(x),x$20)=0,arbitraryconstants=traditional):
interface(warnlevel=0):
kernelopts('assertlevel'=2):
kernelopts(numcpus=1);
kernelopts(gcmaxthreads=1);
interface(rtablesize=100);
latex:-Settings(useimaginaryunit=i,
usecolor = false,
powersoftrigonometricfunctions= mixed, ## computernotation,
leavespaceafterfunctionname = true,
cacheresults = false,
spaceaftersqrt = true,
usetypesettingcurrentsettings=true,
linelength=1000000
plots[setoptions](font=[TIMES,12], labelfont=[TIMES,16]);
plots[setoptions3d](font=[TIMES,12], labelfont=[TIMES,24]);
_EnvUseHeavisideAsUnitStep:=true;
local gamma;
libname := "/home/me/my.mla", libname:
I see from the print messages I have, that both codes run exactly the same steps as ofcourse should be the case as it is the same function. But when running from worksheet, I keep getting these internal Maple errors when calling odetest in the function called after running for sometime. But no errors from command line.
In the worksheet I have it setup so that each worksheet uses its own math engine.
This also happens when starting from clean worksheet with restart.
So there must be something different in running code in .mla from worksheet vs. command to cause this.
Some sort of memory or stack issue or something like this?. But I have no idea what it can be as I expected same code to run the same way.
I am not able to make MWE so far since it uses the whole .mla and code is very large also code uses SQL database. I tried to make small MWE, but the error from worksheet do not show up then. Only when running the whole program it shows up.
But why does odetest behave different when running code from worksheet vs. command line Maple?
This always happens when calling odetest inside timelimit in the function in question. I also use
`assuming/restore_previous_state`;
In all my try/catch calls. I wonder if this has anything to do with this difference in behavior. I will try next to remove all calls to the above and see if this is what causing the problem. But stil the question is, why behaves different when called from worksheet vs. command line?
I am asking general question here: Should there be difference in how proc() in .mla behaves when called from command line vs. worksheet? Any one had similar experience in Maple?
Any ideas or guesses what can cause this, Or anything I can try to help find the cause? I will try them as I gave up figuring this one.
Does Maple math engine internally makes any checks if it called from worksheet vs. command line? Or does the worksheet itself changes some settings that can cause some math engine function such as odetest to behave different? I do not see how this is can be the case.
Any additional information needed, will be happy to provide it,
(#5654 for my reference)
Update
Good news. I am able to make a MWE which reproduces this bug.
It happens when running many many such calls.
Here is the worksheet. It is large, because the Maple bug only happens when running this sequence of calling odetest. And it happens in worksheet. I will now make version for command line which should not give error. But for now, this is the worksheet version. For me, it gives this error each time. But if you do not see the error, try again from the top of the worksheet.
Note. I am adding the same initialization code I used in both worksheet and command line. Which is
to the top of the worksheet. But the Maple error shows up with or without using the above 3 lines of code.
Download error_in_worksheet_but_not_in_command_line_oct_28_2025.mw
Below is same exact code but run in command line Maple. It produces no error
#run this A.mpl file using
#/home/me/maple2025/bin/maple A.mpl
Physics:-Version();
SupportTools:-Version();
verify_it:=proc(sol,ode,func)
local the_status;
try
the_status:=timelimit(30,odetest(sol,ode,func)):
if the_statu<>0 then
the_status:=timelimit(30, (odetest(sol,ode,func) assuming integer));
fi;
if the_status<>0 then
the_status:=timelimit(30, (odetest(sol,ode,func) assuming integer,positive));
fi;
the_status:= timelimit(30, (odetest(sol,ode,func) assuming positive));
fi;
the_status:=timelimit(30, (odetest(sol,ode,func) assuming x<1));
fi;
timelimit(30, (odetest(sol,ode,func) assuming x>1));
fi;
catch:
NULL;
end try:
sol:=ln(x)-_C1+Intat(1/z/(-1-1/6/(z*3^(1/2)*(27*z^2-2*z)^(1/2)-9*z^2)^(1/3)*(-6*z*(z
*3^(1/2)*(27*z^2-2*z)^(1/2)-9*z^2)^(1/3)+6^(2/3)*((z^3*(-3*(27*z^2-2*z)^(1/2)*3
^(1/2)+27*z-1))^(1/3)+z))/z),z = x*y(x)) = 0:
ode:=2*x^3*diff(y(x),x)^3+6*x^2*y(x)*diff(y(x),x)^2-(1-6*x*y(x))*y(x)*diff(y(x),x)+2
*y(x)^3 = 0:
verify_it(sol,ode,y(x)):
sol:=ln(x)-_C2+Intat(1/z/(-1+1/4*((-I*3^(1/6)*2^(2/3)+1/3*6^(2/3))*(z^3*(-3*(27*z^2-\
2*z)^(1/2)*3^(1/2)+27*z-1))^(1/3)+z*(I*3^(1/6)*2^(2/3)+1/3*6^(2/3)+4*(z*(27*z^2
-2*z)^(1/2)*3^(1/2)-9*z^2)^(1/3)))/(z*(27*z^2-2*z)^(1/2)*3^(1/2)-9*z^2)^(1/3)/z
),z = x*y(x)) = 0:
*y(x)^3 = 0:
sol:=ln(x)-_C3+Intat(1/z/(-1-1/4/(z*(27*z^2-2*z)^(1/2)*3^(1/2)-9*z^2)^(1/3)*((-I*3^(
1/6)*2^(2/3)-1/3*6^(2/3))*(z^3*(-3*(27*z^2-2*z)^(1/2)*3^(1/2)+27*z-1))^(1/3)+z*
(I*3^(1/6)*2^(2/3)-1/3*6^(2/3)-4*(z*(27*z^2-2*z)^(1/2)*3^(1/2)-9*z^2)^(1/3)))/z
),z = x*y(x)) = 0:
*y(x)^3 = 0:
*y(x)^3 = 0:
),z = x*y(x)) = 0:
*y(x)^3 = 0:
),z = x*y(x)) = 0:
*y(x)^3 = 0:
sol:=ln(x)-_C1+Intat(1/z/(-1-1/6*(-6*z*(z*3^(1/2)*(27*z^2-2*z)^(1/2)-9*z^2)^(1/3)+6^
(2/3)*((z^3*(-3*(27*z^2-2*z)^(1/2)*3^(1/2)+27*z-1))^(1/3)+z))/(z*3^(1/2)*(27*z^
2-2*z)^(1/2)-9*z^2)^(1/3)/z),z = x*y(x)) = 0:
ode:=diff(y(x),x) = 1/6/x^2*6^(1/3)*(y(x)*(3^(1/2)*(y(x)*(27*x*y(x)-2)/x)^(1/2)-9*y(
x))*x^2)^(1/3)+1/6*y(x)/x*6^(2/3)/(y(x)*(3^(1/2)*(y(x)*(27*x*y(x)-2)/x)^(1/2)-9
*y(x))*x^2)^(1/3)-1/x*y(x):
sol:=Intat(1/(6^(1/3)*tau+(-3^(1/2)*(3*3^(1/2)*tau-(tau*(27*tau-2))^(1/2))*tau)^(2/3
))*(-3^(1/2)*(3*3^(1/2)*tau-(tau*(27*tau-2))^(1/2))*tau)^(1/3),tau = x*y(x)) =
6^(1/3)*ln(x^(1/6))+_C2:
sol:=ln(x)-_C3+Intat(1/z/(-1-1/4*((-I*3^(1/6)*2^(2/3)-1/3*6^(2/3))*(z^3*(-3*3^(1/2)*
(27*z^2-2*z)^(1/2)+27*z-1))^(1/3)+z*(I*3^(1/6)*2^(2/3)-1/3*6^(2/3)-4*(z*3^(1/2)
*(27*z^2-2*z)^(1/2)-9*z^2)^(1/3)))/(z*3^(1/2)*(27*z^2-2*z)^(1/2)-9*z^2)^(1/3)/z
),z = x*y(x)) = 0:
ode:=diff(y(x),x) = -1/12/x^2*6^(1/3)*(y(x)*(3^(1/2)*(y(x)*(27*x*y(x)-2)/x)^(1/2)-9*
y(x))*x^2)^(1/3)-1/12*y(x)/x*6^(2/3)/(y(x)*(3^(1/2)*(y(x)*(27*x*y(x)-2)/x)^(1/2
)-9*y(x))*x^2)^(1/3)-1/x*y(x)-1/2*I*3^(1/2)*(1/6/x^2*6^(1/3)*(y(x)*(3^(1/2)*(y(
x)*(27*x*y(x)-2)/x)^(1/2)-9*y(x))*x^2)^(1/3)-1/6*y(x)/x*6^(2/3)/(y(x)*(3^(1/2)*
(y(x)*(27*x*y(x)-2)/x)^(1/2)-9*y(x))*x^2)^(1/3)):
),z = x*y(x)) = 0:
sol:=-ln(x) = Intat(-(1+I*3^(1/2))*(-(27*_a-2)^(1/2)*3^(1/2)+9*_a^(1/2))^(1/3)*6^(2/
3)/_a^(1/2)/(I*3^(5/6)*2^(1/3)+2*(-(27*_a-2)^(1/2)*3^(1/2)+9*_a^(1/2))^(2/3)-6^
(1/3)),_a = x*y(x))+_C5:
sol:=ln(y)-_C6+Intat(1/z/(-1-(1-I*3^(1/2))*z*6^(2/3)*(z^2*(((27*z-2)/z)^(1/2)*3^(1/2
)-9))^(1/3)/(-2*(z^2*(((27*z-2)/z)^(1/2)*3^(1/2)-9))^(2/3)+z*(3*I*3^(1/6)*2^(2/
3)-6^(2/3))*(z^2*(((27*z-2)/z)^(1/2)*3^(1/2)-9))^(1/3)+I*3^(5/6)*2^(1/3)*z+6^(1
/3)*z)),z = x(y)*y) = 0:
ode:=diff(x(y),y) = (3^(1/2)*(-3*3^(1/2)*y+(y*(27*x(y)*y-2)/x(y))^(1/2))*y*x(y)^2)^(
1/3)*x(y)^2*6^(2/3)*(I*3^(1/2)-1)/(-1/12*6^(2/3)*(I*3^(1/2)-1)*(-I*6^(2/3)*3^(1
/2)+6^(2/3)+12*(3^(1/2)*(-3*3^(1/2)*y+(y*(27*x(y)*y-2)/x(y))^(1/2))*y*x(y)^2)^(
1/3))*x(y)*y+2*(3^(1/2)*(-3*3^(1/2)*y+(y*(27*x(y)*y-2)/x(y))^(1/2))*y*x(y)^2)^(
2/3)):
2/3)):
sol:=ln(y(x))-_C6+Intat(1/z/(-1-(1-I*3^(1/2))*z*6^(2/3)*(z^2*(((27*z-2)/z)^(1/2)*3^(
1/2)-9))^(1/3)/(-2*(z^2*(((27*z-2)/z)^(1/2)*3^(1/2)-9))^(2/3)+z*(3*I*3^(1/6)*2^
(2/3)-6^(2/3))*(z^2*(((27*z-2)/z)^(1/2)*3^(1/2)-9))^(1/3)+I*3^(5/6)*2^(1/3)*z+6
^(1/3)*z)),z = x*y(x)) = 0:
sol:=ln(x)-_C7+Intat(1/z/(-1+1/4*((-I*3^(1/6)*2^(2/3)+1/3*6^(2/3))*(z^3*(-3*(27*z^2-\
),z = x*y(x)) = 0:
)-9*y(x))*x^2)^(1/3)-1/x*y(x)+1/2*I*3^(1/2)*(1/6/x^2*6^(1/3)*(y(x)*(3^(1/2)*(y(
),z = x*y(x)) = 0:
sol:=-ln(x) = Intat(-2/_a^(1/2)*((27*_a-2)^(1/2)*3^(1/2)-9*_a^(1/2))^(1/3)/(-I*3^(5/
6)*2^(1/3)+I*3^(1/2)*((27*_a-2)^(1/2)*3^(1/2)-9*_a^(1/2))^(2/3)-((27*_a-2)^(1/2
)*3^(1/2)-9*_a^(1/2))^(2/3)-6^(1/3))*6^(2/3),_a = x*y(x))+_C9:
print("DONE. Did you see any errors?");
exit();
Here is the result
|\^/| Maple 2025 (X86 64 LINUX)
._|\| |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2025
\ MAPLE / All rights reserved. Maple is a trademark of
<____ ____> Waterloo Maple Inc.
| Type ? for help.
> interface(version);
Command-line Interface, Maple 2025.1, X86 64 LINUX, Jun 12 2025, Build ID 1932578
> Physics:-Version();
The "Physics Updates" version in the MapleCloud is 1881 and is the same as the version installed in this computer, created 2025, October 7, \
16:4 hours Pacific Time.
The Customer Support Updates version in the MapleCloud is 29 and is the same as the version installed in this computer, created June 23, 202\
5, 10:25 hours Eastern Time.
32
numcpus
[10, 10]
> local the_status;
> try
> fi;
> fi;
> fi;
> fi;
> fi;
> catch:
> NULL;
> end try:
> end proc:
> *y(x)^3 = 0:
memory used=35.6MB, alloc=108.3MB, time=0.19
memory used=121.3MB, alloc=116.3MB, time=0.54
memory used=200.1MB, alloc=144.3MB, time=0.87
memory used=321.1MB, alloc=176.3MB, time=1.35
memory used=384.3MB, alloc=176.3MB, time=1.63
memory used=474.4MB, alloc=176.3MB, time=2.00
memory used=624.5MB, alloc=184.3MB, time=2.57
memory used=759.0MB, alloc=184.3MB, time=3.14
memory used=893.1MB, alloc=184.3MB, time=3.72
> ),z = x*y(x)) = 0:
> *y(x)^3 = 0:
memory used=1035.8MB, alloc=184.3MB, time=4.27
memory used=1169.9MB, alloc=184.3MB, time=4.83
memory used=1302.5MB, alloc=184.3MB, time=5.38
memory used=1423.7MB, alloc=184.3MB, time=5.90
memory used=1552.0MB, alloc=184.3MB, time=6.42
memory used=1667.7MB, alloc=184.3MB, time=6.93
memory used=1795.9MB, alloc=184.3MB, time=7.46
memory used=1921.7MB, alloc=184.3MB, time=7.99
memory used=2035.4MB, alloc=184.3MB, time=8.49
> ),z = x*y(x)) = 0:
> *y(x)^3 = 0:
memory used=2154.0MB, alloc=184.3MB, time=9.00
memory used=2278.5MB, alloc=184.3MB, time=9.53
memory used=2399.9MB, alloc=184.3MB, time=10.04
memory used=2509.9MB, alloc=184.3MB, time=10.52
memory used=2627.5MB, alloc=184.3MB, time=11.02
memory used=2732.8MB, alloc=184.3MB, time=11.48
memory used=2849.4MB, alloc=184.3MB, time=11.97
memory used=2955.4MB, alloc=184.3MB, time=12.45
memory used=3069.4MB, alloc=184.3MB, time=12.93
> *y(x)^3 = 0:
memory used=3173.5MB, alloc=216.3MB, time=13.41
memory used=3322.2MB, alloc=216.3MB, time=14.05
memory used=3466.2MB, alloc=216.3MB, time=14.68
memory used=3605.1MB, alloc=216.3MB, time=15.29
memory used=3743.9MB, alloc=216.3MB, time=15.89
memory used=3882.0MB, alloc=216.3MB, time=16.51
> ),z = x*y(x)) = 0:
> *y(x)^3 = 0:
memory used=4029.8MB, alloc=216.3MB, time=17.11
memory used=4159.8MB, alloc=216.3MB, time=17.70
memory used=4299.4MB, alloc=216.3MB, time=18.29
memory used=4434.6MB, alloc=216.3MB, time=18.86
memory used=4557.8MB, alloc=216.3MB, time=19.42
memory used=4701.2MB, alloc=248.3MB, time=20.00
> ),z = x*y(x)) = 0:
> *y(x)^3 = 0:
memory used=4863.9MB, alloc=248.3MB, time=20.70
memory used=5031.5MB, alloc=248.3MB, time=21.41
memory used=5195.2MB, alloc=248.3MB, time=22.11
memory used=5346.8MB, alloc=248.3MB, time=22.76
memory used=5505.1MB, alloc=248.3MB, time=23.42
memory used=5662.7MB, alloc=248.3MB, time=24.09
memory used=5819.2MB, alloc=248.3MB, time=24.76
memory used=5967.8MB, alloc=248.3MB, time=25.44
memory used=6122.7MB, alloc=248.3MB, time=26.17
memory used=6282.9MB, alloc=280.3MB, time=26.88
memory used=6458.2MB, alloc=280.3MB, time=27.67
memory used=6632.0MB, alloc=280.3MB, time=28.47
memory used=6824.1MB, alloc=280.3MB, time=29.31
memory used=6997.3MB, alloc=280.3MB, time=30.11
memory used=7185.8MB, alloc=280.3MB, time=30.94
memory used=7352.2MB, alloc=280.3MB, time=31.70
memory used=7511.5MB, alloc=280.3MB, time=32.44
memory used=7691.1MB, alloc=280.3MB, time=33.23
memory used=7852.5MB, alloc=312.3MB, time=33.99
memory used=8061.4MB, alloc=312.3MB, time=34.94
memory used=8272.3MB, alloc=312.3MB, time=35.84
> ),z = x*y(x)) = 0:
memory used=8467.0MB, alloc=312.3MB, time=36.70
memory used=8678.4MB, alloc=312.3MB, time=37.59
memory used=8886.0MB, alloc=344.3MB, time=38.46
memory used=9099.1MB, alloc=344.3MB, time=39.43
memory used=9317.0MB, alloc=344.3MB, time=40.39
memory used=9549.3MB, alloc=344.3MB, time=41.36
> ),z = x*y(x)) = 0:
memory used=9758.9MB, alloc=344.3MB, time=42.33
memory used=9986.7MB, alloc=344.3MB, time=43.29
memory used=10213.4MB, alloc=376.3MB, time=44.25
memory used=10438.1MB, alloc=376.3MB, time=45.26
memory used=10674.2MB, alloc=376.3MB, time=46.31
memory used=10939.1MB, alloc=376.3MB, time=47.36
memory used=11157.9MB, alloc=376.3MB, time=48.37
memory used=11397.1MB, alloc=376.3MB, time=49.36
memory used=11635.9MB, alloc=376.3MB, time=50.33
memory used=11843.8MB, alloc=376.3MB, time=51.27
memory used=12045.3MB, alloc=408.3MB, time=52.21
memory used=12325.2MB, alloc=408.3MB, time=53.28
memory used=12596.4MB, alloc=408.3MB, time=54.33
> 2/3)):
> 2/3)):
memory used=12834.3MB, alloc=408.3MB, time=55.38
memory used=13093.0MB, alloc=408.3MB, time=56.51
memory used=13325.7MB, alloc=440.3MB, time=57.54
memory used=13576.1MB, alloc=440.3MB, time=58.67
memory used=13834.9MB, alloc=440.3MB, time=59.79
memory used=14096.1MB, alloc=440.3MB, time=60.95
> ),z = x*y(x)) = 0:
memory used=14339.1MB, alloc=440.3MB, time=62.07
memory used=14599.6MB, alloc=440.3MB, time=63.21
memory used=14905.7MB, alloc=504.3MB, time=64.42
memory used=15179.6MB, alloc=488.3MB, time=65.73
memory used=15487.1MB, alloc=488.3MB, time=67.03
> ),z = x*y(x)) = 0:
memory used=15758.8MB, alloc=488.3MB, time=68.34
memory used=16065.9MB, alloc=520.3MB, time=69.68
memory used=16378.3MB, alloc=520.3MB, time=71.08
memory used=16680.5MB, alloc=520.3MB, time=72.47
memory used=16982.9MB, alloc=520.3MB, time=73.86
memory used=17292.8MB, alloc=520.3MB, time=75.22
memory used=17593.5MB, alloc=520.3MB, time=76.51
memory used=17860.3MB, alloc=552.3MB, time=77.77
memory used=18212.4MB, alloc=552.3MB, time=79.18
memory used=18534.1MB, alloc=552.3MB, time=80.58
> exit();
exit()
> quit
memory used=18554.9MB, alloc=552.3MB, time=80.69
You see, no error.
