Question: should simplify evaluate a limit which was not evaluated before?
This is a question on semantics I suppose.
Maple dsolve returns a solution with a limit in it, because the limit do not exist or Maple could not find the limit. Which is fine.
Then why does simplify() applied to the solution returns undefined?  Now it appears that Maple solution is y(x)=undefined, which does not make much sense.
Should it not have left the solution with the limit in place as is? i.e. since dsolve could not find limit, how did simplify managed to replace the limit by undefined?
Is this considered an expected behavior by simplify?
Firewall changed its mind again today and will not let me upload worksheet. Here is code
ode:=4*x*diff(y(x),x$2)+2*diff(y(x),x)+y(x)=(6+x)/x^2;
IC:=y(infinity)=0;
sol:=dsolve([ode,IC],y(x)); #OK, maple can't find limit. No problem
simplify(sol)
