Question: Why doesn't the Minkowski metric appear in proper form in spherical coordinates on initialization?
I want the Minkowski metric in spherical coordinates, so I do the following:
with(Physics):
Setup(coordinatesystems=spherical,signature=`-+++`);
`Systems of spacetime coordinates are:`*{X = (t, r, theta, phi)}
[coordinatesystems = {X}, signature = `- + + +`]
g_[lineelement]
-Physics:-d_(t)^2+Physics:-d_(r)^2+Physics:-d_(theta)^2+Physics:-d_(phi)^2
Which is not correct, it should return:
-d_(t)^2 + d_(r)^2 + r^2*d_(theta)^2 + r^2*sin(theta)^2*d_(phi)^2
Any ideas why it is giving the wrong answer? I usually just define my metric manually, but I was curious why this is occuring. I also noticed something else strange: after running the worksheet, if I go back to the setup line and execute, it will return the correct expression! But if I execute restart and then Setup again, wrong answer.
Any thoughts would be appreciated, thanks!
