Question: parametric plot of a complex function
Goal: to make a 3D parametric plot of a complex function u(x,t) obtained by pdsolve.  I tried to follow one example of a plot of a complex expression/function.  I was unable to get any plot.  I got some warning and error.  Please let me know what have I done wrong.
I follow this example so that I can get a 3D parametric plot of a complex function u(x,t) for a fix x:
with(plots);
complexplot(exp(t*I), t = 0 .. 2*Pi, scaling = constrained);
plot([cos(t), sin(t), t = 0 .. 2*Pi], scaling = constrained);
z := t -> exp(t*I);
spacecurve([Re(z(t)), Im(z(t)), t], t = 0 .. 4*Pi, axes = normal, labels = ["Re", "Im", "t"]);
It was successful.  With the following pde, I obtain an analytical solution using pdsolve.
a := 3;
L := 2*Pi;
d := 0.5;
T0 := 2*Pi;
PDE := diff(u(x, t), t, t) = a^2*diff(u(x, t), x, x) - d*diff(u(x, t), t);
IBC := u(x, 0) = cos(Pi*x/L), D[2](u)(x, 0) = 0, D[1](u)(0, t) = 0, D[1](u)(L, t) = 0;
pds := pdsolve({IBC, PDE}, u(x, t));
It fail 2D plotting using the following:
with(plots);
complexplot(u(0, t), t = 0 .. 6);
So I break down the pds with the following:
RP := Re(pds);
IP := Im(pds);
RP0 := eval(RP, x = 0);
RP0t := unapply(RP0, t);
IP0 := eval(IP, x = 0);
IP0t := unapply(IP0, t);
And I was hopeful as the following give me real numbers when I approximate them:
RP0t(1);
                     Re(u(0, 1)) = 0.20248
RP0t(2);
                     Re(u(0, 2)) = -0.57765
But it fails in both 2D and 3D plot:
plot([RP0t(t), t = 0 .. 6])
spacecurve([RP0t(t), IP0t(t), t], t = 0 .. 6, axes = normal)
