Question: how to check this solution is correct by Maple dsolve?
Not able to make odetest give zero on this Maple solution to this first order ode.
So not sure if solution is correct or not, as can't also get same solution by hand.
Any one can find a method or way to verify this solution is correct?
odetest says it satisfies the IC but not the ode itself.
Below is worksheet. Tried with Maple 2026 and 2025.2 both give same solution.
Site will not let me upload worksheet. Here is code
ode:=diff(diff(y(x),x),x)+sin(y(x)) = 0;
IC:=y(infinity) = Pi;
sol:=[dsolve([ode,IC])];
the_residue:=odetest(sol[1],[ode,IC]);
the_residue:=odetest(sol[2],[ode,IC]);
Tried many things, including different assumptions, but can't get zero.
