Question: Is this a valid list operation?
Note that Maple 2026 is not an available option on the product list above. This operation was used in Maple 2026.
I obtained code for the shuffle product of two lists from the AI Assistant. Included in the code was the following list operation to extract a sublist.:
 defined list  u:=[a,b,c]:  extract the sublist using the operation u[2..-1] which gives correct result [b.c]
Normally, I would have expected this operation would be encoded as [op(2..-1),u] .
Is the shortcut notion reliable or should the operation have been encoded using op() to be safe.
