Question: How to make debugger not show intermediate results?
I was trying to use the debugger into a proc that has this call
P:=plots:-contourplot(RHS,':-colorbar' = false,':-contours' = L):
Even though the proc has : at its end, and the above call to plots also ends with :, the debugger insists in printing to the debugger window the contour cuves lines. i.e the value of P
Is there a way to tell the debugger not to do this? i.e. not show the value of P. It seems it does that automatically.
Here is the worksheet. Simply evaluate the call foo(); this will open a debugger windows. Then click on next button and now debugger will print  the output of plots:-contourplot(RHS,':-colorbar' = false,':-contours' = L):
kernelopts('assertlevel'=2):
kernelopts(numcpus=1);
32
`Standard Worksheet Interface, Maple 2026.1, Windows 10, April 28 2026 Build ID 2011354`
foo:=proc()
local L := [$ -4 .. 4]:
local RHS:=y/tan(x):
local P,T:
DEBUG();
T:= timelimit(60,plottools:-getdata(P,'rangesonly')):
foo();  #this will open a debugger window
Download hang_maple_2026_1_on_timelimit.mw
Here is screen shot
In my main actual code, the output was so large that it hanged Maple UI when stepping into the debugger and hitting that line.  I had to kill Maple from task manager as Java UI got stuck due to large output.
Why is it showing value of P when I have : at the end? Is there an option to turn automatic display of variables in debugger as one steps in?
