Question: Error in Typesetting after loading edited module from startup code area
I am attaching two worksheets.  The first worksheet titled testflaw shows the original state of a module. The module in the startup code area contained two exported variables which were never implemented. The module had been used in testing the code.  The second worksheet testflaw2 shows the result after deleting the exported variables. (AsTable and TestAssociativity).  Note that when the worksheet opens a typesetting error code occurs.  It appears that the typesetting routines retain knowledge of the exported variables even after a Restart command.
testflaw.mw
testflaw.mw
