Question: System of Differential Equations
Hi all,
I have a system of differential equations:
Eq1:=diff(R(t), t) = -0.22*W(t)-3000+0.3*R(t)+3488*exp(0.295e-3*t)+.744*(diff(W(t), t))
Eq2:=diff(W(t), t) = 0.304*W(t)-0.1916e-1*R(t)-2981*exp(0.295e-3*t)+2180-.36*H(t)+.6*(diff(R(t), t))
To solve, I could plug Eq1 into Eq2. However, maple will also solve this system without plugging Eq1 into Eq2. But, I see the answers are different. So, which method is correct?
This issue came to my attention when say Eq1 is zero. In this case, should I plug the equation in Eq2, or should I just make the last term in Eq2 equal to zero?
Thanks for your help!
-Steve
